Grafana MySQL -> PostgreSQL migration
Hello there!
For operational reasons we would like to move our Grafana installation from a MySQL database to a PostgreSQL database.
Does anybody know what’s the best way to approach this task?
I was wondering if theres some kind of automated way to export the current settings as a whole (configuration, organization, groups, users, dashboards, datasources etc) in order to re-import them later into another grafana instance (this would help me a lot of course)
I’m currently running grafana v7.4.5 (8a2c78d3f8) running as a docker container in a Kubernetes cluster.
Migrate from MySQL to PostgreSQL while keeping as much data as possible.
Thank you in advance,
Znpy
Just checking @znpy
You are aware that Grafana’s default db is SQLite, yes? So this is an installation where you’ve already migrated from SQLite to MySQL?
Hi @mattbrams and thank you for your reply!
This installation was configured to use MySQL from the beginning. I authored the config.ini myself at the time, configuring MySQL from the beginning.
Does this help in any way?
Thank you!
Nothing ?
@anon70503803 at this point a negative reply would be fine too, at least I know I have start thinking about setting up a new grafana instance and perform a migration to it :sweat_smile:
Thank you anyway for your help though! :slight_smile:
sorry I can’t be more helpful, @znpy
if you do attempt a migration, let us know about the experience. Maybe we can add a helper script like this one for migrating from SQLite to MySQL:
Big pain point for many people migration. But seems not a grafana issue?
you could extract from mysql as csv and try to restore it that way?
facing the same requirement, mysql to pg. not sure who has a successful experience.
Why are you migrwting from mysql to pg.
Also its really an issue outside of grafana?
I made it by pgloader the schema “grafana_draft” would auto created to database of “dbname” with same name.
docker run --rm --name pgloader dimitri/pgloader:latest pgloader --with “batch rows = 200” --with “prefetch rows = 200” --with “workers = 4” --with “concurrency = 1” ‘mysql://username:aa@mysqlhost/grafana_draft’ ‘pgsql://draft:password@hostname/dbname’
Shall we try migrating to SQLite from MySQL and then migrate from SQLite to PostgreSQL again?
@znpy what worked for you?
Even we are facing the similar issue.
Ref: mysql-to-sqlite3 · PyPI
that would be brutal approach.
here is one
and this
Migrate Grafana SQLite DB to Postgresql for High Availability | by Yashraj Dighe | Medium.
