I have a local Grafana install that I set up for internal monitoring, but other departments have started using it. I would like to move it off of the utility server I initially installed it on to it’s own machine so I can set up external access and have the appropriate security in place.
My question is do I need to recreate data sources if I migrate everything? I see multiple posts describing what to copy, but none of them mention if I need to recreate each data source individually. I’m using SQL, Azure, PRTG, Prometheus and a couple other sources.
Thanks!
