Grafana v8.3.3 (30bb7a93ca) - Windows
Hi there,
Can you please advise why a Panel with the same configurations in terms of grouping of query terms setting yet is sending different order for the terms value. Please see attached screen shot for the configuration of the panel and another one for the state history.
Please review and advise
Many thanks
Jamil
@jamilsaab are you able to share the results from the data column of the query inspector for each query? It might give some insight into what the query result looks like for each. It’s hard to say without seeing the data.
HI there,
Please find attached as requested in the below link. Please use3 passwords bziiansf84X73rP to access the files:
https://fileportal.supportservices.asia/public/?folder=0884f99d
I hope I got it right
Thanks
Jamil
