Metric queries and extracted labels
Not sure what I am doing wrong here, because this seems like a basic case for metrics from logs. I’m trying to create a panel that is a table of ips and their count in the query range. I have tried many things, but the closest I have gotten is this:
count by(ip) (rate({job=“$job”, service=“$service”} |= $filter | regexp (?P<ip>\d{1,3}\.\d{1,3}\.\d{1,3}\.\d{1,3}) | error=`` [30m]))
The result of this query is seperate datasets for each extracted ip, with the fields being “Time” and the resulting count for that time. I figure I am either:
A. Doing the query wrong, is this a case were I need unwrap?
B. Need to do something else now to join the datasets
Using loki 3.1 and Grafana 11. Thanks for the advice.
I guess you’re seeing multiple tables in Table visualization? You can use a transformation Reduce with option Series to Rows (default one) and calculation from the time series.
Explanation:
I’m not certain but I guess your query creates time series. You cannot display a time series in a table (at least not in the way you’d like), therefore you have to pick a certain number (Total / Max / Last) from the series to have a compact table you’d (probably) like.
Yes! That is exactly what I was looking for, and your explanation makes sense. Thanks!
