It appears that Transform’s Median is not functioning properly.
Max, Mean, and Last display the calculation results correctly.
Please open the following link and try it.
When I select Median, nothing is displayed.
This is the same behavior in docker Grafana 11.2.2.
https://play.grafana.org/d/OhR1ID6Mk/table?editPanel=4
Also try Group By in this link.
Nothing shows up when I select Median here either.
https://play.grafana.org/d/svrdAH4Vk/group-by-time-test?editPanel=2
docker grafana/grafana-enterprise:11.2.2-ubuntu -
I want to derive the median -
We are trying to achieve this with Median in Calculations. -
What happened?
When Median is specified for Calculations, nothing is displayed. -
Correct median value should be displayed.
