MAX parameter of gauge can not be set under 0.01
Dear Forum,
I am using docker with grafana-oss latest version. I am facing an issue with displaying small numbers (<0.001).
For values in the mirco range the “Max“ parameter can not be adjusted under 0.01 without causing gauge rendering problems. Thresholds take small values just fine, no problems there.
Sure, I can prescale my measurement values as a simple workaround. But maybe this is a bug that is worth to fix.
Best Jens
set thresholds mode to % then see
Plenty Thanks to infofcc3 your tip works like a charm.
