Gauge threshold labels is overlappging
Grafana version: v7.5.7
I was using gauge, but there is a weird layout, like below.
The max value and threshold value is overlapping in gauge.
how to avoid the threshold overlap the max value.
other info:
min: 5
max: 104
thresholds: 50, 100
value: 36
I would submit a bug for that so that the angle of those numbers maybe can be controlled
