Need suggestion and advise on this issue. i was unable to increase the size of the value in the dashboard. BY default its too small and not able to view correctly.
- What Grafana version and what operating system are you using? 8.1 - Cloud
what panel (visualization) are you using, @muhammadmurad ?
And what version of grafana?
Thanks for checking this. i am able to find the way how to increase those. I am using flowcharting plugins. my version is 8.1.5. Thank you
