Making a Pie Chart for a boolean field with true/false labels
    Grafana v11.1.4 (2355de00c6) on Linux
    I want a pie chart to represent a boolean custom field myPrefix.isMySuffix from an elasticsearch data source. I want the segments to be labelled true/false (or yes/no or 1/0).
  1. In the query, I am using the Metrics tab and have selected Metric: Count and Group By: Terms: myPrefix.isMySuffix.
  2. In [the options pane > Value options], I specified Show: All values and Fields: Count.
  • What happened?
    I get a pie chart where both segments are labelled ‘Count’.
    I expected that the labels would correspond to the values true/false (which are the values in my data for the field myPrefix.isMySuffix.
  "datasource": {
    "type": "elasticsearch",
    "uid": "REDACTED"
  "fieldConfig": {
    "defaults": {
      "custom": {
        "hideFrom": {
          "tooltip": false,
          "viz": false,
          "legend": false
      "color": {
        "mode": "palette-classic"
      "mappings": []
    "overrides": []
  "gridPos": {
    "h": 8,
    "w": 6,
    "x": 6,
    "y": 1
  "id": 2,
  "options": {
    "reduceOptions": {
      "values": true,
      "calcs": [
        "count"
      "fields": "/^Count$/"
    "pieType": "pie",
    "tooltip": {
      "mode": "single",
      "sort": "none"
    "legend": {
      "showLegend": true,
      "displayMode": "list",
      "placement": "bottom",
      "values": [
        "percent"
    "displayLabels": [
      "name",
      "value"
  "pluginVersion": "11.1.4",
  "targets": [
      "alias": "",
      "bucketAggs": [
          "field": "myPrefix.isMySuffix",
          "id": "2",
          "settings": {
            "min_doc_count": "0",
            "order": "desc",
            "orderBy": "_term",
            "size": "2"
          "type": "terms"
      "datasource": {
        "uid": "REDACTED"
      "hide": false,
      "metrics": [
          "hide": false,
          "id": "1",
          "type": "count"
      "query": "",
      "refId": "B",
      "timeField": "@timestamp"
  "title": "REDACTED",
  "type": "piechart"
    No errors
    No particular online instructions
can you please post sample es doc? obfuscate it if needed but keep doc structure intact
Sure. I imagined that was the configuration I shared above. Can you tell me how to obtain my es doc?
If you use ES query tool via cli or kibana ?
I’m using kibana
Im having the same problem, did you able to find a solution eventually?
Yes, I used the ‘+ Add field override’ button at the bottom of the right aisle to create two overrides:
  1. (Override 1) Fields with name: true; Standard options > Display name: ‘true’
  2. (Override 2) Fields with name: false; Standard options > Display name: ‘false’
