Grafana Latest (11.3.0) & Loki v2.9.0 -
I want to get a “pie chart” that shows the different browsers people have used to access my Apache web server. The information should be collected from the logs. The logs look like this:
::1 - - [28/Oct/2024:19:26:15 +0100] "GET / HTTP/1.1" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/130.0.0.0 Safari/537.36" -
With the following query, I’m sending the browsers by JSON to labels with the browsers label:
{job="apache-logs"}
| pattern `<ip> - - \[<timestamp>\] "<method> <path> <protocol>" <status> <size> "-" "<user_agent>"`
| regexp "(?P<browser>(Firefox|Chrome|Safari|Edge|Opera))"
| label_format browser="{{.browser}}"
after that, I use transformations:
- Extract fields to extract the
browserlabel from labels. - Filter by data value to ignore null or empty browsers.
- Organize fields by name to hide all columns except the
browsercolumn.
This leaves me with a single column named “Browsers,” containing as many rows as there are values, with each row showing a browser name (e.g., 4 rows with “Firefox,” 10 rows with “Chrome,” etc.).
When I put it in a pie chart, it only shows “browser” and doesn’t display the different browsers. - Can you copy/paste the configuration(s) that you are having problems with?
"id": 12,
"type": "table",
"title": "Browsers",
"gridPos": {
"x": 0,
"y": 0,
"h": 8,
"w": 12
"fieldConfig": {
"defaults": {
"custom": {
"align": "auto",
"cellOptions": {
"type": "auto"
"inspect": false
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"value": null,
"color": "green"
"value": 80,
"color": "red"
"color": {
"mode": "thresholds"
"overrides": []
"transformations": [
"id": "extractFields",
"options": {
"source": "labels",
"format": "json",
"replace": true,
"keepTime": false
"id": "filterByValue",
"options": {
"filters": [
"fieldName": "browser",
"config": {
"id": "equal",
"options": {
"value": ""
"config": {
"id": "isNull",
"options": {}
"type": "exclude",
"match": "any"
"id": "organize",
"options": {
"excludeByName": {
"filename": true,
"ip": true,
"job": true
"indexByName": {},
"renameByName": {
"browser": ""
"includeByName": {}
"id": "reduce",
"options": {
"reducers": [],
"mode": "seriesToRows",
"includeTimeField": false,
"labelsToFields": false
"pluginVersion": "11.3.0",
"targets": [
"refId": "A",
"editorMode": "code",
"expr": "{job=\"apache-logs\"} \r\n| pattern `<ip> - - \\[<timestamp>\\] \"<method> <path> <protocol>\" <status> <size> \"-\" \"<user_agent>\"`\r\n| regexp \"(?P<browser>(Firefox|Chrome|Safari|Edge|Opera))\"\r\n| label_format browser=\"{{.browser}}\"\r\n",
"queryType": "range"
"datasource": {
"uid": "fe1uj54ymy5tsc",
"type": "loki"
"options": {
"showHeader": true,
"cellHeight": "sm",
"footer": {
"show": false,
"reducer": [
"sum"
"countRows": false,
"fields": ""
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No errors - Did you follow any online instructions? If so, what is the URL?
No
