import "math"
from(bucket: "Lybover")
|> filter(fn: (r) => r["topic"] == "RAGG_UF_Flow")
|> filter(fn: (r) => r["_field"] == "metrics_0_value")
|> filter(fn: (r) => r["_measurement"] == "mqtt_consumer")
|> filter(fn: (r) => r["host"] == "machinedatalinux")
|> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false)
|> map(fn: (r) => ( _time: r._time, _value: math.sqrt((2.0 * r._value) / 2232.93)))
|> yield(name: "mean")
In your query, the issue is likely in the map()
function.
import "math"
|> map(fn: (r) => ({
_time: r._time,
|> yield(name: "mean")
Welcome @didiertimmerman
If you run your query in Influx Data Explorer, the debugger will tell you the line number and space where the LPAREN error is occurring.
