Loki StatefulSet Scheduling Issues on EKS with Multi-AZ EBS Volumes
We recently deployed Loki in an EKS management cluster and ran into scheduling issues related to EBS volume zone affinity and Loki ingester topology. Posting the details here in case it helps others running Loki on Kubernetes with AWS EBS.
Environment
  • Kubernetes: Amazon EKS
  • Storage: AWS EBS (gp2)
  • Deployment: Loki Helm Chart
  • Cluster: multi-AZ (us-west-2a / us-west-2b / us-west-2c)
  • Loki components deployed in Kubernetes (distributed mode)
The cluster node groups span multiple AZs, which is standard for EKS.
Issue:
Loki ingesters use persistent volumes. On AWS, EBS volumes are single-AZ resources.
When a PVC is created, the corresponding PV is provisioned in a specific AZ.
Example PV:
labels:
  topology.kubernetes.io/zone: us-west-2b
During node drains (for example, during EKS upgrades or autoscaling), pods were rescheduled onto nodes in other AZs.
Example scheduler error:
0/8 nodes are available:
4 node(s) didn't match PersistentVolume's node affinity
The pod could not start because the PV existed in a different availability zone.
Why does this happen?
Loki’s zone aware replication uses logical zones (zone-a, zone-b, zone-c), but these do not automatically map to AWS availability zones.
As a result:
loki-ingester-zone-a pod
→ may schedule on any node
→ PVC may be created in a different AWS AZ
Later during rescheduling, Kubernetes enforces:
PV zone must match node zone
which causes scheduling failures.
Additional Scheduling Constraints
Ingester pods also use pod anti-affinity:
only one ingester per node
Combined with:
  • node drains
  • autoscaling
  • limited node capacity
this can lead to pods remaining Pending during cluster operations.
Example error:
2 node(s) didn't match pod anti-affinity rules
4 node(s) didn't match Pod's node affinity/selector
Solution:
We solved the issue by pinning Loki stateful components to a single AZ. And Loki recommends it-
Example Helm configuration:
ingester:
  nodeSelector:
This ensures:
Pod zone = Node zone = PV zone
which satisfies EBS volume constraints.
Do we have any better solution? If others are running Loki on EKS with EBS storage, it would be great to hear how you handle multi-AZ scheduling for ingesters.
For Mimir, it works fine using-
ZoneAwareReplication:
enabled: true
topologyKey: kubernetes.io/hostname
zones:
  - name: zone-a
nodeSelector:
topology.kubernetes.io/zone: us-west-2a
  - name: zone-b
nodeSelector:
  - name: zone-c
nodeSelector:
topology.kubernetes.io/zone: us-west-2c
Are you using EBS CSI driver?
Yes, we have the EBS CSI driver. We also have Mimir and multiple zones that work fine. e.g.
The backend is S3, but we have kept EBS is needed for local storage.
zoneAwareReplication:
    enabled: true
zones:
      - name: zone-a
nodeSelector:
      - name: zone-b
nodeSelector:
  - name: zone-c
nodeSelector:
How about scaler?
We don’t run Loki on EKS, so I can’t test for you, but we have other workloads on EKS with stateful EBS volumes and karpenter and I’ve never seen this on our cluster.
Yes, we have autoscalers installed, but they are not effective because Loki is unable to map AWS EBS volume regions to the corresponding PVCs.
And we can’t move Loki out of EKS :slightly_frowning_face:
