Loki slow if query range is more than 7 days
Hello, we have started using loki for the logs,and while for shorter time range it works great, but for bigger range, > 7days, we see it being too slow.
We have a nodepool of 3 nodes of 8 Cpu, 32 GB Ram in GKE. the config is below.
I especially want to learn if the tsdb_max_query_parallelism and split_queries_by_interval config is alright for the requirement?
deploymentMode: SimpleScalable
gateway:
  tolerations:
    - key: "dedicated"
      operator: "Equal"
      value: "logs"
      effect: "NoSchedule"
  basicAuth:
    enabled: true
loki:
  image:
    tag: 3.5.1
  runtimeConfig:
    overrides:
      prod:
        retention_period: 720h # 30 days
        ingestion_rate_mb: 100
        ingestion_burst_size_mb: 100
        per_stream_rate_limit: 5MB
        per_stream_rate_limit_burst: 20MB
        max_line_size: 256Kb
        max_line_size_truncate: true
  server:
    # https://grafana.com/docs/tempo/latest/troubleshooting/querying/response-too-large/
    grpc_server_max_recv_msg_size: 30485760
    grpc_server_max_send_msg_size: 30485760
  limits_config:
    reject_old_samples: true
    shard_streams:
      enabled: true
    allow_structured_metadata: true
    volume_enabled: true
    split_queries_by_interval: 1h
    max_query_parallelism: 100
    tsdb_max_query_parallelism: 350
    max_line_size: 512000
  chunk_store_config:
    chunk_cache_config:
      background:
        writeback_buffer: 5000
        writeback_goroutines: 1
        writeback_size_limit: 500MB
      memcached:
        batch_size: 3
        parallelism: 2
      memcached_client:
        addresses: dnssrvnoa+_memcached-client._tcp.loki-chunks-cache.logs.svc
        consistent_hash: true
        max_idle_conns: 72
        timeout: 60s
  query_range:
    parallelise_shardable_queries: true
    align_queries_with_step: true
    cache_results: true
    results_cache:
      cache:
        background:
          writeback_buffer: 500000
        default_validity: 6h
        memcached_client:
          addresses: dnssrvnoa+_memcached-client._tcp.loki-results-cache.logs.svc
          timeout: 60s
          update_interval: 1m
          # max_item_size: 5m
  storage_config:
    hedging:
      at: 250ms
      max_per_second: 20
      up_to: 3
  auth_enabled: true
  frontend_worker:
    grpc_client_config:
  schemaConfig:
    configs:
        store: tsdb
        object_store: gcs
        schema: v13
        index:
          prefix: loki_index_
          period: 24h
  ingester:
    chunk_encoding: snappy
  querier:
    # Default is 4, if you have enough memory and CPU you can increase, reduce if OOMing
    max_concurrent: 9
  pattern_ingester:
    enabled: true
  compactor:
    retention_enabled: true
    delete_request_store: gcs
  storage:
    bucketNames:
      chunks: chunks
      ruler: ruler
    type: gcs
    gcs:
      chunkBufferSize: 0
      requestTimeout: "10s"
      enableHttp2: true
chunksCache:
  allocatedMemory: 4096
  maxItemMemory: 2
  replicas: 2
  tolerations:
    - key: "dedicated"
      operator: "Equal"
      value: "logs"
resultsCache:
  defaultValidity: 8h
  maxItemMemory: 5
  replicas: 2
  tolerations:
    - key: "dedicated"
      operator: "Equal"
      value: "logs"
backend:
  replicas: 2
  tolerations:
    - key: "dedicated"
      operator: "Equal"
      value: "logs"
read:
  replicas: 4
  tolerations:
    - key: "dedicated"
      operator: "Equal"
      value: "logs"
  resources:
    requests:
      cpu: 1000m
  affinity:
    podAntiAffinity:
      requiredDuringSchedulingIgnoredDuringExecution:
        - labelSelector:
            matchLabels:
              app.kubernetes.io/component: read
          topologyKey: kubernetes.io/hostname
    nodeAffinity:
      preferredDuringSchedulingIgnoredDuringExecution:
        - weight: 50
          preference:
            matchExpressions:
              - key: dedicated
                operator: In
                values:
                  - logs
  autoscaling:
    enabled: true
    minReplicas: 4
    maxReplicas: 8
    targetCPUUtilizationPercentage: 80
    behavior:
      scaleUp:
      stabilizationWindowSeconds: 300
      policies:
        - type: Pods
          value: 1
          periodSeconds: 60
      scaleDown:
      policies:
        - type: Pods
          value: 1
          periodSeconds: 180
write:
  replicas: 3 # To ensure data durability with replication
  tolerations:
    - key: "dedicated"
      operator: "Equal"
      value: "logs"
minio:
  enabled: false
lokiCanary:
  enabled: false
test:
  enabled: false
monitoring:
  dashboards:
    enabled: true
  serviceMonitor:
    enabled: true
split_queries_by_interval set to 1h is fine. How much volume is 7 days of logs roughly?
Also, I’d check your query frontend logs and make sure your queries are actually being split properly. Also there are some useful information on Query frontend example | Grafana Loki documentation
