How can I enhance my Loki Query Performance for large amounts of time ranges?
I’m enhancing a microservice deployment of Loki already in place.
We have our logs on S3 (2.0TB of logs are stored, ingestion of around 30Gb/day).
When I try to query 6 months back on my dashboard, I get slow responses or 502. The dashboard has 11 Visualizations with graphs and tables.
By increasing A LOT of my resources, I get a bit of better performance, but we are not happy with the costs and the performance we are getting. Can someone help me with tips for my helm values.yaml configs to enhance performance and lower the resources at the same time?
We are getting a 30-day query in around 2 minutes; our goal is to lower it down to 30 seconds.
values.yaml:
loki:
  limits_config:
    max_streams_per_user: 1000000
    max_line_size_truncate: true
    max_label_name_length: 5048
    max_label_value_length: 5120
    increment_duplicate_timestamp: true
    max_query_series: 1000000
    max_query_parallelism: 5000
    query_timeout: 15m
    max_query_length: 0s
    ingestion_rate_mb: 10
    tsdb_max_query_parallelism: 5000
    discover_log_levels: false
    per_stream_rate_limit: 10MB
    per_stream_rate_limit_burst: 50MB
    retention_period: 9600h # 400 days
    split_queries_by_interval: 12h
    max_concurrent_tail_requests: 150
  per_tenant_override_config: /etc/overrides.yaml
  schemaConfig:
    configs:
        store: tsdb
        object_store: s3
        schema: v13
        index:
          prefix: loki_index_
          period: 24h
  compactor:
    working_directory: /var/loki/data/compactor
    compaction_interval: 10m
    retention_enabled: true
    retention_delete_delay: 0s
    retention_delete_worker_count: 150
    delete_request_store: aws
  ingester:
    chunk_encoding: snappy
  querier:
    # Default is 4, if you have enough memory and CPU you can increase, reduce if OOMing
    max_concurrent: 15
  tracing:
    enabled: true
  memcached:
    chunk_cache:
      enabled: true
      service: "memcache"
    results_cache:
      enabled: true
      service: "memcache"
      default_validity: 12h
  storage:
    type: "s3"
    s3:
      region: us-east-1
    bucketNames:
      chunks: myapp-loki
      ruler: myapp-loki
      admin: myapp-loki
  structuredConfig:
    chunk_store_config:
      skip_query_writeback_cache_older_than: 168h
      l2_chunk_cache_handoff: 168h
      chunk_cache_config_l2:
        background:
          writeback_goroutines: 10
        memcached:
          expiration: 168h
          batch_size: 200
          parallelism: 200
        memcached_client:
          service: "memcache"
      chunk_cache_config:
        memcached:
          expiration: 168h
          batch_size: 200
          parallelism: 200
gateway:
  resources:
    requests:
      cpu: "500m"
      memory: "2Gi"
    limits:
      cpu: "500m"
      memory: "2Gi"
  replicas: 4
  autoscaling:
    # -- Enable autoscaling for the gateway
    enabled: true
    # -- Minimum autoscaling replicas for the gateway
    minReplicas: 4
    # -- Maximum autoscaling replicas for the gateway
    maxReplicas: 6
    # -- Target CPU utilisation percentage for the gateway
    targetCPUUtilizationPercentage: 60
    # -- Target memory utilisation percentage for the gateway
    targetMemoryUtilizationPercentage:
    # -- See `kubectl explain deployment.spec.strategy` for more
    # -- ref: https://kubernetes.io/docs/concepts/workloads/controllers/deployment/#strategy
    # -- Behavior policies while scaling.
    behavior:
      scaleUp:
       stabilizationWindowSeconds: 300
       policies:
       - type: Pods
         value: 1
         periodSeconds: 60
      scaleDown:
       policies:
       - type: Pods
         value: 1
         periodSeconds: 180
  ingress:
    # -- Specifies whether an ingress for the gateway should be created
    enabled: true
    # -- Ingress Class Name. MAY be required for Kubernetes versions >= 1.18
    ingressClassName: "alb"
    # -- Annotations for the gateway ingress
    annotations:
      external-dns.alpha.kubernetes.io/hostname: gateway.loki.myapp.int
      alb.ingress.kubernetes.io/scheme: internal
      alb.ingress.kubernetes.io/security-groups: SECURITY_GROUP_ID
      alb.ingress.kubernetes.io/manage-backend-security-group-rules: "false"
      alb.ingress.kubernetes.io/listen-ports: '[{"HTTP": 8080}]'
      alb.ingress.kubernetes.io/target-type: ip
      alb.ingress.kubernetes.io/ip-address-type: ipv4
      alb.ingress.kubernetes.io/target-group-attributes: deregistration_delay.timeout_seconds=30,slow_start.duration_seconds=0,load_balancing.algorithm.type=least_outstanding_requests
      alb.ingress.kubernetes.io/load-balancer-attributes: idle_timeout.timeout_seconds=900
      nginx.ingress.kubernetes.io/proxy-read-timeout: "900"
      nginx.ingress.kubernetes.io/proxy-send-timeout: "900"
      nginx.ingress.kubernetes.io/proxy-connect-timeout: "900"
    # -- Hosts configuration for the gateway ingress, passed through the `tpl` function to allow templating
    hosts:
      - host: gateway.loki.myapp.int
        paths:
          - path: /
            # -- pathType (e.g. ImplementationSpecific, Prefix, .. etc.) might also be required by some Ingress Controllers
            pathType: Prefix
chunksCache:
  allocatedMemory: 30000
  defaultValidity: 24h
  parallelism: 200
  batchSize: 1000
  replicas: 4
  enabled: true
  resources:
    requests:
      cpu: "1"
      memory: "30Gi"
    limits:
      cpu: "1"
      memory: "30Gi"
deploymentMode: Distributed
ingester:
  maxUnavailable: 1
  replicas: 15
  resources:
    requests:
      cpu: "4"
      memory: "8Gi"
    limits:
      cpu: "4"
      memory: "8Gi"
querier:
  replicas: 40
  maxUnavailable: 1
  resources:
    requests:
      cpu: "14"
      memory: "14Gi"
    limits:
      cpu: "14"
      memory: "14Gi"
queryFrontend:
  maxUnavailable: 1
  replicas: 10
  resources:
    requests:
      cpu: "8"
      memory: "8Gi"
    limits:
      cpu: "8"
      memory: "8Gi"
  cache:
    enabled: true
    memcached:
      service: "memcache"
queryScheduler:
  maxUnavailable: 1
  replicas: 5
  resources:
    requests:
      cpu: "1"
      memory: "500Mi"
    limits:
      cpu: "1"
      memory: "500Mi"
distributor:
  replicas: 4
  maxUnavailable: 1
  resources:
    requests:
      cpu: "2"
      memory: "500Mi"
    limits:
      cpu: "2"
      memory: "500Mi"
indexGateway:
  replicas: 40
  maxUnavailable: 1
  resources:
    requests:
      cpu: "4"
      memory: "16Gi"
    limits:
      cpu: "4"
      memory: "16Gi"
minio:
  enabled: false
serviceAccount:
  annotations:
    "eks.amazonaws.com/role-arn": ROLE_ARN
compactor:
  replicas: 0
  maxUnavailable: 1
  resources:
    requests:
      cpu: "2"
      memory: "10Gi"
# Zero out replica counts of other deployment modes
singleBinary:
  replicas: 0
bloomBuilder:
  replicas: 0
bloomCompactor:
  replicas: 0
bloomGateway:
  replicas: 0
write:
  replicas: 0
read:
  replicas: 0
backend:
  replicas: 0
If you have 2TB of logs with 400-day retention, then querying 6 months worth of logs could potentially be 800GB (most likely less, but still), and there is a chance you might just not be able to get that to work within a reasonable time frame for various reasons.
We don’t allow our users to query for more than a month of duration, so I can’t say I’ve had the same problem, but couple of things you can try:
  1. Make sure query splitting is actually processed in parallel. You should either need a downstream URL or frontend address in your config (see Query frontend example | Grafana Loki documentation ). You should be able to tell by running a query with logcli (or api), it’ll give you some stats after a query.
  2. In general it’s better to have more but smaller queriers as opposed to bigger and fewer. With 12-hour split theoretically you could cover 60-day worth of logs with 120 queries, and with 2TB of logs each of the querier would just need 2GB of memory. Then you could lower from there, and say maybe do 4GB of memory but with more concurrency and half the count.
  3. Send your Loki metrics somewhere (prometheus, for example), and see if you can spot the bottleneck. If S3 becomes a problem, maybe consider migrating to using multiple S3 buckets instead of just one.
You may also consider joining the grafana community Slack. There are some people running impressively large clusters, hopefully they can give you some pointers I can’t.
Query performance depends on the query. Could you provide a sample of queries which work slowly in your Grafana dashboard? This will simplify understanding why your queries are slow. You can replace sensitive information in these queries by some random words.
As a last resort, try another database for logs: ElasticSearch, ClickStack, VictoriaLogs. Probably, some of these databases will give you higher query performance.
