Hello all,
I’d like to upgrade my loki helm deployment on my cluster from version 3.8.1. to version 5.22.0 without losing any of my data. My current deployment looks like this:
apiVersion: helm.toolkit.fluxcd.io/v2beta1
kind: HelmRelease
metadata:
spec:
chart:
spec:
chart: loki
sourceRef:
kind: HelmRepository
version: 3.8.1
interval: 10m0s
values:
loki:
storage:
type: filesystem
auth_enabled: false
test:
enabled: false
monitoring:
dashboards:
enabled: false
rules:
enabled: false
serviceMonitor:
enabled: false
selfMonitoring:
enabled: false
grafanaAgent:
installOperator: false
lokiCanary:
enabled: false
singleBinary:
replicas: 3
persistence:
storageClass: local
As you can see I use filesystemas storage and 3 replicas of the singlebinary, which is not allowed without proper storage in later versions. I want to deploy a newer version, without the loss of any data, as loki is used extensively.
Is this possible, or do I have to just switch to 1 singlebinary pod and start migrating from there? What would be the safest solution?
