Loki don't persist data
I’m using AKS and using helm grafana/loki-stack to install it, but I can’t persist volumes and if I restart my loki’s pod, I lose all logs. After installing with these custom values, I had the same results:
persistence:
enableStatefulSetAutoDeletePVC: false
type: pvc
enabled: true
storageClass: “managed-csi”
Regards
Please share your configuration.
Also, you should consider storing your Loki data in azure storage.
Hi! I use the default configuration using helm chart as: helm install loki grafana/loki-stack --values loki-values.yaml and my loki-values.yaml is:
persistence:
type: pvc
enabled: true
Regards
