I succeed Loki’s “SimpleScalable” deployment mode using S3 as storage. Now I have cleaned S3 buckets, and hope to try “Distributed” mode.
Based on
- loki-distributed 0.80.1 · grafana/grafana
- loki/production/helm/loki/values.yaml at main · grafana/loki · GitHub
- loki/production/helm/loki/distributed-values.yaml at main · grafana/loki · GitHub
- Install the microservice Helm chart | Grafana Loki documentation
I wrote my deployment code:
apiVersion: argoproj.io/v1alpha1
kind: Application
metadata:
namespace: production-hm-argo-cd
labels:
app.kubernetes.io/name: hm-loki
spec:
project: production-hm
sources:
- repoURL: https://grafana.github.io/helm-charts
# https://artifacthub.io/packages/helm/grafana/loki
targetRevision: 0.80.1
chart: loki-distributed
helm:
releaseName: hm-loki
values: |
deploymentMode: Distributed
serviceAccount:
create: true
annotations:
eks.amazonaws.com/role-arn: arn:aws:iam::272394222652:role/LokiRole-hm-loki
loki:
auth_enabled: true
schemaConfig:
configs:
store: tsdb
object_store: s3
schema: v13
index:
prefix: loki_index_
period: 24h
storage_config:
aws:
region: us-west-2
bucketnames: production-hm-loki-chunk-bucket
s3forcepathstyle: false
boltdb_shipper:
shared_store: s3
compactor:
shared_store: s3
pattern_ingester:
enabled: true
ingester:
chunk_encoding: zstd
max_chunk_age: 24h
limits_config:
# https://grafana.com/docs/grafana/latest/explore/simplified-exploration/logs/access/
allow_structured_metadata: true
volume_enabled: true
querier:
max_concurrent: 4
compactor:
retention_enabled: true
delete_request_store: s3
ruler:
enable_api: true
storage:
type: s3
s3:
region: us-west-2
bucketnames: production-hm-loki-ruler-bucket
storage:
type: s3
s3:
region: us-west-2
bucketNames:
chunks: production-hm-loki-chunk-bucket
ruler: production-hm-loki-ruler-bucket
admin: production-hm-loki-admin-bucket
distributor:
replicas: 3
maxUnavailable: 1
ingester:
replicas: 3
maxUnavailable: 2
zoneAwareReplication:
enabled: false
querier:
replicas: 3
maxUnavailable: 2
queryFrontend:
replicas: 2
maxUnavailable: 1
queryScheduler:
replicas: 2
compactor:
replicas: 1
indexGateway:
replicas: 2
maxUnavailable: 1
bloomPlanner:
replicas: 0
bloomBuilder:
replicas: 0
bloomGateway:
replicas: 0
minio:
enabled: false
# Zero out replica counts of monolithic deployment mode
singleBinary:
replicas: 0
# Zero out replica counts of simple scalable deployment mode
backend:
replicas: 0
read:
replicas: 0
write:
replicas: 0
- repoURL: git@github.com:hongbo-miao/hongbomiao.com.git
targetRevision: main
path: kubernetes/argo-cd/applications/production-hm/loki/kubernetes-manifests
destination:
namespace: production-hm-loki
server: https://kubernetes.default.svc
syncPolicy:
syncOptions:
- ServerSideApply=true
automated:
prune: true
However, this gives me error
at least one bucket name must be specified
github.com/grafana/loki/pkg/storage/chunk/client/aws.buckets
/src/loki/pkg/storage/chunk/client/aws/s3_storage_client.go:335
github.com/grafana/loki/pkg/storage/chunk/client/aws.NewS3ObjectClient
/src/loki/pkg/storage/chunk/client/aws/s3_storage_client.go:154
github.com/grafana/loki/pkg/storage.NewObjectClient
/src/loki/pkg/storage/factory.go:621
github.com/grafana/loki/pkg/storage.NewChunkClient
/src/loki/pkg/storage/factory.go:451
github.com/grafana/loki/pkg/storage.(*store).chunkClientForPeriod
/src/loki/pkg/storage/store.go:200
github.com/grafana/loki/pkg/storage.(*store).init
/src/loki/pkg/storage/store.go:164
github.com/grafana/loki/pkg/storage.NewStore
/src/loki/pkg/storage/store.go:155
github.com/grafana/loki/pkg/loki.(*Loki).initStore
/src/loki/pkg/loki/modules.go:690
github.com/grafana/dskit/modules.(*Manager).initModule
/src/loki/vendor/github.com/grafana/dskit/modules/modules.go:136
github.com/grafana/dskit/modules.(*Manager).InitModuleServices
/src/loki/vendor/github.com/grafana/dskit/modules/modules.go:108
github.com/grafana/loki/pkg/loki.(*Loki).Run
/src/loki/pkg/loki/loki.go:461
main.main
/src/loki/cmd/loki/main.go:110
runtime.main
/usr/local/go/src/runtime/proc.go:271
runtime.goexit
/usr/local/go/src/runtime/asm_amd64.s:1695
error creating object client
/src/loki/pkg/storage/store.go:202
main.main
runtime.main
runtime.goexit
error initialising module: store
/src/loki/vendor/github.com/grafana/dskit/modules/modules.go:138
main.main
runtime.main
runtime.goexit
level=warn ts=2025-02-17T23:36:30.768798099Z caller=loki.go:288 msg="global timeout not configured, using default engine timeout (\"5m0s\"). This behavior will change in the next major to always use the default global timeout (\"5m\")."
level=info ts=2025-02-17T23:36:30.770080649Z caller=main.go:108 msg="Starting Loki" version="(version=2.9.10, branch=HEAD, revision=7664eda07b)"
level=info ts=2025-02-17T23:36:30.770488633Z caller=server.go:322 http=[::]:3100 grpc=[::]:9095 msg="server listening on addresses"
level=info ts=2025-02-17T23:36:30.771113623Z caller=memberlist_client.go:434 msg="Using memberlist cluster label and node name" cluster_label=hm-loki.production-hm-loki node=hm-loki-loki-distributed-ingester-2-36639255
level=info ts=2025-02-17T23:36:30.771130514Z caller=modules.go:1342 msg="failed to initialize usage report" err="at least one bucket name must be specified"
level=warn ts=2025-02-17T23:36:30.771151019Z caller=experimental.go:20 msg="experimental feature in use" feature="In-memory (FIFO) cache - embedded-cache"
level=warn ts=2025-02-17T23:36:30.771210656Z caller=cache.go:127 msg="fifocache config is deprecated. use embedded-cache instead"
level=warn ts=2025-02-17T23:36:30.771216642Z caller=experimental.go:20 msg="experimental feature in use" feature="In-memory (FIFO) cache - chunksembedded-cache"
level=error ts=2025-02-17T23:36:30.771357894Z caller=log.go:230 msg="error running loki" err="at least one bucket name must be specified\ngithub.com/grafana/loki/pkg/storage/chunk/client/aws.buckets\n\t/src/loki/pkg/storage/chunk/client/aws/s3_storage_client.go:335\ngithub.com/grafana/loki/pkg/storage/chunk/client/aws.NewS3ObjectClient\n\t/src/loki/pkg/storage/chunk/client/aws/s3_storage_client.go:154\ngithub.com/grafana/loki/pkg/storage.NewObjectClient\n\t/src/loki/pkg/storage/factory.go:621\ngithub.com/grafana/loki/pkg/storage.NewChunkClient\n\t/src/loki/pkg/storage/factory.go:451\ngithub.com/grafana/loki/pkg/storage.(*store).chunkClientForPeriod\n\t/src/loki/pkg/storage/store.go:200\ngithub.com/grafana/loki/pkg/storage.(*store).init\n\t/src/loki/pkg/storage/store.go:164\ngithub.com/grafana/loki/pkg/storage.NewStore\n\t/src/loki/pkg/storage/store.go:155\ngithub.com/grafana/loki/pkg/loki.(*Loki).initStore\n\t/src/loki/pkg/loki/modules.go:690\ngithub.com/grafana/dskit/modules.(*Manager).initModule\n\t/src/loki/vendor/github.com/grafana/dskit/modules/modules.go:136\ngithub.com/grafana/dskit/modules.(*Manager).InitModuleServices\n\t/src/loki/vendor/github.com/grafana/dskit/modules/modules.go:108\ngithub.com/grafana/loki/pkg/loki.(*Loki).Run\n\t/src/loki/pkg/loki/loki.go:461\nmain.main\n\t/src/loki/cmd/loki/main.go:110\nruntime.main\n\t/usr/local/go/src/runtime/proc.go:271\nruntime.goexit\n\t/usr/local/go/src/runtime/asm_amd64.s:1695\nerror creating object client\ngithub.com/grafana/loki/pkg/storage.(*store).chunkClientForPeriod\n\t/src/loki/pkg/storage/store.go:202\ngithub.com/grafana/loki/pkg/storage.(*store).init\n\t/src/loki/pkg/storage/store.go:164\ngithub.com/grafana/loki/pkg/storage.NewStore\n\t/src/loki/pkg/storage/store.go:155\ngithub.com/grafana/loki/pkg/loki.(*Loki).initStore\n\t/src/loki/pkg/loki/modules.go:690\ngithub.com/grafana/dskit/modules.(*Manager).initModule\n\t/src/loki/vendor/github.com/grafana/dskit/modules/modules.go:136\ngithub.com/grafana/dskit/modules.(*Manager).InitModuleServices\n\t/src/loki/vendor/github.com/grafana/dskit/modules/modules.go:108\ngithub.com/grafana/loki/pkg/loki.(*Loki).Run\n\t/src/loki/pkg/loki/loki.go:461\nmain.main\n\t/src/loki/cmd/loki/main.go:110\nruntime.main\n\t/usr/local/go/src/runtime/proc.go:271\nruntime.goexit\n\t/usr/local/go/src/runtime/asm_amd64.s:1695\nerror initialising module: store\ngithub.com/grafana/dskit/modules.(*Manager).initModule\n\t/src/loki/vendor/github.com/grafana/dskit/modules/modules.go:138\ngithub.com/grafana/dskit/modules.(*Manager).InitModuleServices\n\t/src/loki/vendor/github.com/grafana/dskit/modules/modules.go:108\ngithub.com/grafana/loki/pkg/loki.(*Loki).Run\n\t/src/loki/pkg/loki/loki.go:461\nmain.main\n\t/src/loki/cmd/loki/main.go:110\nruntime.main\n\t/usr/local/go/src/runtime/proc.go:271\nruntime.goexit\n\t/usr/local/go/src/runtime/asm_amd64.s:1695"
Any guide would be appreciate, thanks!
