Is there a way to run Loki in clustered mode without/outside kubernetes? Any guide on the steps and where can i find the binaries?
I assume I’ll need Ingester, Querrier and Distributor.
Hi @rizwankh ,
Can you explain a bit more about what you are trying to achieve and why? What is the intent here?
I was able to figure that out. The same binary can be configured using target to run as a different component. I wanted to setup the cluster manually on 3 servers.
