Loki alerting via ruler doesn't work
Ubuntu 20.04.4 LTS; Grafana v7.5.15
Ruler block in config:
ruler:
  storage:
    type: local
    local:
      directory: /etc/loki/rules
  rule_path: /tmp/loki/rules-temp
  alertmanager_url: http://localhost:9093
  ring:
    kvstore:
      store: inmemory
  enable_api: true
  enable_alertmanager_v2: true
storage_config:
  boltdb:
    directory: /var/lib/loki/index
  filesystem:
    directory: /var/lib/loki/chunks
test.rules in /etc/loki/rules
- name: test_alerts
  rules:
    - alert: test_alert
      annotations:
        message: "{{ $labels.pod }} is alerting by test rule"
      expr: 'count_over_time({pod=~".+"}[1m] |~ ".+") > 200'
      for: 0m
      labels:
        severity: critical
The rules I expect to look when making HTTP request but don’t get:
curl -sX GET http://127.0.0.1:3100/prometheus/api/v1/rules | jq .
  "status": "success",
  "data": {
    "groups": []
  "errorType": "",
  "error": ""
and no one alert in alertmanager
The way the issue was resolved is to move all rules from /etc/loki/rules to /etc/loki/rules/fake
The reason why it should work such way is not clear for me.
The reason for this is because the rules need to be storied under your tenant id, so where you specified fake, it should actually be your tenant id.
