Viewing current/active loki ruler alert/recording rules
Hi.
I have managed to configured a loki ruler and some alert rules, and have successfully integrated with AlertManager.
My question is: how do you see/verify the alerting rules are loaded and working?
In prometheus you can verify the configuration via the UI - and easily troubleshoot promql etc. There does not appear to be a similar option in the grafana - unless I’m missing something?
Effectively, once the ruler is configured and the rules loaded, the only clue I have as to what is going on is monitoring the log output of loki, which is not ideal. So it does not build any confidence that the rules are going to work.
Hope you can help.
Thanks.
Just bumping this issue in the hope that some body has some idea about this!
