Loki 3.6.10 Ruler: "stored rulegroup" logged but rules not persisted to S3
Hi all,
We’re experiencing an issue where the Loki ruler logs “stored rulegroup” but rules are not actually written to S3. Interestingly, log chunks work fine on the same S3 endpoint.
Environment
  • Loki version: 3.6.10
  • Deployment: Kubernetes (Simple Scalable mode)
  • Storage: S3-compatible (Dell ECS)
  • Config: use_thanos_objstore: false (legacy ruler.storage)
Symptoms
  1. Rules pushed via API → Loki logs msg="stored rulegroup"
  2. S3 rules bucket remains empty
  3. Ruler polls S3 → msg="failed to get rule group"
  4. Rules disappear from Grafana
What works
  • Log chunks write to S3 successfully (same endpoint, same credentials)
  • Logs are queryable
  • AWS CLI can write to the rules bucket manually
Related issues we found
  • #21848 - Added ChecksumAlgorithm: SHA256 triggering aws-chunked
  • #24214 - Fix merged in 3.6.16: “Pre-compute SHA-256 to avoid aws-chunked”
  • #24206 - Reports silent corruption on S3-compatible backends
Questions
  1. Does the aws-chunked issue affect ruler storage specifically? Why would logs work but not rules on the same endpoint?
  2. Will upgrading to 3.6.16+ fix this for ruler storage?
  3. Has anyone else experienced this with S3-compatible storage?
Thanks for any insights!
Can you share your config, please?
Thanks for the quick response! Here’s our configuration and additional findings.
### Loki Configuration (sanitized)
```yaml
auth_enabled: false
common:
compactor_grpc_address: ‘loki-backend.logging.svc.cluster.local:9095’
path_prefix: /var/loki
replication_factor: 3
storage:
s3:
access_key_id: ${LOKI_S3_ACCESS_KEY}
bucketnames: ${LOKI_S3_BUCKET_NAME}
endpoint: ${LOKI_S3_ENDPOINT}
http_config:
response_header_timeout: 15s
insecure: false
s3forcepathstyle: true
secret_access_key: ${LOKI_S3_SECRET_KEY}
ruler:
alertmanager_url: http://prometheus-kube-prometheus-alertmanager.prometheus:9093
enable_api: true
storage:
s3:
http_config:
insecure: false
type: s3
wal:
dir: /var/loki/ruler-wal
storage_config:
hedging:
at: 250ms
max_per_second: 20
up_to: 3
schema_config:
configs:
index:
period: 24h
prefix: loki_index_
object_store: s3
schema: v11
store: boltdb-shipper
index:
period: 24h
prefix: loki_tsdb_index_
object_store: s3
schema: v13
store: tsdb
# Other relevant settings
limits_config:
max_query_length: 2165h
max_query_parallelism: 50
query_timeout: 5m
### Additional Findings
After further investigation, we discovered the root cause:
**The rules ARE being persisted to S3** - we verified this by listing objects in the bucket:
rules/fake/YWxsb3ktazYtY29yZS10ZXN0LXNjOTAtd29ya2Zsb3dzLWxvZy1hbGVydHMt…/c2M5MC13b3JrZmxvd3MtbG9nLWFsZXJ0cw==
**The issue is with GetObject, not PutObject.** Our S3-compatible storage (Dell ECS) is returning HTTP 500 errors on ~20% of GetObject requests:
| Operation | Success (200) | Failure (500) | Error Rate |
| GetObject | 1,600,817 | 401,454 | **20%** |
| PutObject | 304,792 | 1 | ~0% |
This explains why:
1. `msg=“stored rulegroup”` appears (PutObject succeeds)
2. `msg=“failed to get rule group”` appears immediately after (GetObject fails)
3. Rules work intermittently (when GetObject succeeds)
### S3 Metrics from Loki
loki_s3_request_duration_seconds_count{operation=“S3.GetObject”,status_code=“200”} 1600817
loki_s3_request_duration_seconds_count{operation=“S3.GetObject”,status_code=“500”} 401454
loki_s3_request_duration_seconds_count{operation=“S3.PutObject”,status_code=“200”} 304792
loki_s3_request_duration_seconds_count{operation=“S3.PutObject”,status_code=“500”} 1
### Questions
1. Is there any known compatibility issue between Loki’s AWS SDK v2 client and S3-compatible storage like Dell ECS?
2. Would enabling `use_thanos_objstore: true` use a different S3 client that might behave differently?
3. Are there any recommended S3 client settings for non-AWS S3-compatible storage?
### Environment
- **Loki Version:** 3.6.10
- **Deployment:** Kubernetes (loki-distributed helm chart)
- **S3 Storage:** Dell ECS (S3-compatible)
- **Ruler Target:** `backend` component
I’ve not used thanos store before, so I can’t tell you. But are you able to pin down why GetObject intermittently fails? Since it only fails 20% of the time it would imply that it’s in fact not compatibility, because it does work, just not always. I’d say see if you can find the error on Dell ECS, and that might give you a clue on how to fix it.
