Currently we have deployed Loki with Grafana and configured alert history correctly. However, in the s3 bucket where chunks and indexes are stored, recently there are no indexes inside the index folder and there is a delete_requests.gz file in the following path:
https://s3.my-region.amazonaws.com/my-bucket-for-loki/index/delete_requests/delete_requests.gz
In the logs we found the following:
caller=util.go:94 file-name=delete_requests.gz size="16 kB" msg="downloaded file"
caller=manager.go:122 msg="deleted rule manager and local rule files" user=fake
We did some tests with the ruler (first local, then s3 storage, local again with another loki instance to work as ruler and then s3 storage definitely with a monolithic deployment), so we suspect this might be related. Is this the expected behaviour (to empty the index folder in the s3 and leave that file)? Note also that we have two different buckets: one for the ruler and one for the index so this shouldn’t have happened, right? Strangely enough, we are able to query our logs just fine.
Additionally, in order to enable alert history Grafana required Loki ruler to have a s3 storage. Why? We have checked the s3 bucket and no rule file is created once we have added the alert rules via Grafana UI.
Just in case this is useful, here is our ruler config:
ruler:
storage:
type: s3
s3:
s3: s3://my-region/my-loki-ruler-bucket
rule_path: /var/tmp/rules
alertmanager_url: http://alertmanager:9093
enable_alertmanager_v2: true
ring:
kvstore:
store: inmemory
prefix: rulers/
enable_api: true
Thanks in advance!
Your issues seem to be all over the place. I’ll try to break it down a bit:
The delete_request.gz file is from compactor if i remember correctly, not from ruler. And unless you specifically set it to write to your S3 backend it should be stored locally (unless this changed with recent release).
If you are able to query your logs there is no way all your index and chunk files are gone. I’d double check your configuration and make sure you understand where your data actually are.
I don’t use alert history, so I can’t comment on it. But in general Grafana requires Loki ruler to have S3 storage if you wish to interact with ruler at all from Grafana. Because in order for Grafana to interact with ruler, ruler needs to have API enabled, and in order to do that ruler needs to have S3 storage as backend. Without S3 backend ruler API is not available, therefore Grafana can’t interact with ruler without it.
Tony, thanks for your answer. May be the way I explained myself wasn’t clear. Currently we have two questions:
why does the compactor delete the indexes in the s3 even when the limits_config is set to 0s and there is no retention_enabled? We managed to figure out it was the compactor deleting the indexes because we removed the deleteObject permissions and began seeing an error of unauthorized in the logs.
why does grafana need loki to have an s3 storage for the ruler, when it doesn’t interact with it? (Or at least, doesn’t seem so because no rules files are being created inside the s3 bucket)
Regarding point 2 (querying chunks with indexes gone) we do have a suspicion: when we changed from file system to s3 to filesystem again, some of the indexes were kept in the filesystem.
I would really appreciate your comments, thanks!
- Sure, here is our Loki config:
auth_enabled: false
server:
http_listen_port: 3100
http_server_read_timeout: 360s
http_server_write_timeout: 360s
grpc_server_max_recv_msg_size: 8388608
grpc_server_max_send_msg_size: 8388608
ingester:
chunk_encoding: snappy
wal:
enabled: true
dir: /loki/wal
common:
ring:
instance_addr: 127.0.0.1
kvstore:
store: inmemory
replication_factor: 1
path_prefix: /loki
schema_config:
configs:
store: tsdb
object_store: s3
schema: v13
index:
prefix: index_
period: 24h
analytics:
reporting_enabled: false
query_scheduler:
max_outstanding_requests_per_tenant: 10000
compactor:
shared_store: s3
working_directory: /loki/compactor
storage_config:
aws:
region: my-region
bucketnames: my-bucket-name
s3: s3://my-region/my-bucket-name
tsdb_shipper:
active_index_directory: /loki/index
cache_location: /loki/index_cache
shared_store: s3
limits_config:
query_timeout: 350s
retention_period: 2160h
enforce_metric_name: false
reject_old_samples: true
max_cache_freshness_per_query: 10m
split_queries_by_interval: 24h
per_stream_rate_limit: "5MB"
per_stream_rate_limit_burst: "15MB"
ingestion_rate_mb: 50
ingestion_burst_size_mb: 100
max_entries_limit_per_query: 1000
max_label_value_length: 20480
max_label_name_length: 10240
max_label_names_per_series: 300
ruler:
storage:
type: s3
s3:
s3: s3://my-region/my-bucket-name-for-ruler
ring:
kvstore:
store: inmemory
prefix: rulers/
enable_api: true
Configured as it is, IT IS trying to delete our indexes; at least this is what we see in the logs:
level=info ts=2024-05-29T22:36:29.398936862Z caller=index_set.go:269 table-name=index_19872 user-id=fake user-id=fake msg="removing source db files from storage" count=126
We tried granting deleteObject to the role, and the indexes were marked for deletion. We recovered them with this script provided by aws Retrieve an Amazon S3 object that was deleted | AWS re:Post and removed the deleteObject permission to the role; until we understand how this works.
- Regarding this, we configured the ruler withe filesystem storage, but got the following error:
level=error msg="GetRuleGroup unsupported in rule local store\n" error="GetRuleGroup unsupported in rule local store\n"
I understand the error comes from here: grafana/public/app/features/alerting/unified/api/buildInfo.ts at 98152b2f84b685d25ae3471a24e6630eedf00ba0 · grafana/grafana · GitHub
Due to this error we configured Loki ruler to use s3 as storage, and the error went away. However, after creating the rules in Grafana (in order to use alert history, alerts must be managed by Grafana) we kind of expected Grafana to save the rules in the s3 bucket of the rule. Plot twist, it doesn’t. So we don’t see the point of Grafana requiring Loki ruler storage to be non-local.
And thanks again for your time
In the config shared above the limits_config retention_period is set to 2160h because we’ve grown suspicious of the 0s default.
Here is the full config from /config:
target: all
http_prefix: ""
ballast_bytes: 0
use_buffered_logger: true
use_sync_logger: true
server:
http_listen_network: tcp
http_listen_address: ""
http_listen_conn_limit: 0
grpc_listen_network: tcp
grpc_listen_address: ""
grpc_listen_port: 9095
grpc_listen_conn_limit: 0
tls_cipher_suites: ""
tls_min_version: ""
http_tls_config:
cert_file: ""
key_file: ""
client_auth_type: ""
client_ca_file: ""
grpc_tls_config:
cert_file: ""
key_file: ""
client_ca_file: ""
register_instrumentation: true
graceful_shutdown_timeout: 30s
http_server_read_timeout: 6m0s
http_server_write_timeout: 6m0s
http_server_idle_timeout: 2m0s
grpc_server_max_concurrent_streams: 100
grpc_server_max_connection_idle: 2562047h47m16.854775807s
grpc_server_max_connection_age: 2562047h47m16.854775807s
grpc_server_max_connection_age_grace: 2562047h47m16.854775807s
grpc_server_keepalive_time: 2h0m0s
grpc_server_keepalive_timeout: 20s
grpc_server_min_time_between_pings: 10s
grpc_server_ping_without_stream_allowed: true
log_format: logfmt
log_level: info
log_source_ips_enabled: false
log_source_ips_header: ""
log_source_ips_regex: ""
log_request_headers: false
log_request_at_info_level_enabled: false
log_request_exclude_headers_list: ""
http_path_prefix: ""
internal_server:
http_listen_address: localhost
http_listen_port: 3101
grpc_listen_network: ""
grpc_listen_port: 0
tls_min_version: ""
http_tls_config:
cert_file: ""
key_file: ""
client_ca_file: ""
grpc_tls_config:
cert_file: ""
key_file: ""
client_ca_file: ""
register_instrumentation: false
http_server_read_timeout: 30s
http_server_write_timeout: 30s
grpc_server_max_recv_msg_size: 0
grpc_server_max_send_msg_size: 0
grpc_server_max_concurrent_streams: 0
grpc_server_max_connection_idle: 0s
grpc_server_max_connection_age: 0s
grpc_server_max_connection_age_grace: 0s
grpc_server_keepalive_time: 0s
grpc_server_keepalive_timeout: 0s
grpc_server_min_time_between_pings: 0s
grpc_server_ping_without_stream_allowed: false
log_format: ""
log_level: ""
enable: false
distributor:
ring:
kvstore:
store: inmemory
prefix: collectors/
consul:
host: localhost:8500
acl_token: ""
http_client_timeout: 20s
consistent_reads: false
watch_rate_limit: 1
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_insecure_skip_verify: false
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_enabled: false
mirror_timeout: 2s
heartbeat_period: 15s
heartbeat_timeout: 1m0s
instance_id: 18b4ed97d8b9
instance_interface_names:
- eth0
- lo
instance_port: 0
instance_enable_ipv6: false
rate_store:
max_request_parallelism: 200
stream_rate_update_interval: 1s
ingester_request_timeout: 500ms
debug: false
write_failures_logging:
rate: 1KB
add_insights_label: false
querier:
tail_max_duration: 1h0m0s
query_ingesters_within: 3h0m0s
engine:
timeout: 5m0s
max_look_back_period: 30s
max_concurrent: 10
query_store_only: false
query_ingester_only: false
multi_tenant_queries_enabled: false
query_timeout: 0s
per_request_limits_enabled: false
query_scheduler:
max_queue_hierarchy_levels: 3
querier_forget_delay: 0s
grpc_client_config:
max_recv_msg_size: 104857600
max_send_msg_size: 104857600
grpc_compression: ""
rate_limit: 0
rate_limit_burst: 0
backoff_on_ratelimits: false
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
initial_stream_window_size: 63KiB1023B
initial_connection_window_size: 63KiB1023B
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
connect_timeout: 5s
connect_backoff_base_delay: 1s
connect_backoff_max_delay: 5s
use_scheduler_ring: true
scheduler_ring:
kvstore:
store: inmemory
prefix: collectors/
consul:
acl_token: ""
watch_rate_limit: 1
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_timeout: 2s
tokens_file_path: ""
zone_awareness_enabled: false
- eth0
- lo
instance_port: 0
instance_availability_zone: ""
frontend:
log_queries_longer_than: 0s
max_body_size: 10485760
query_stats_enabled: false
max_outstanding_per_tenant: 2048
scheduler_address: ""
scheduler_dns_lookup_period: 10s
scheduler_worker_concurrency: 5
grpc_client_config:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
connect_timeout: 5s
graceful_shutdown_timeout: 5m0s
- eth0
- lo
address: ""
port: 0
compress_responses: false
downstream_url: ""
tail_proxy_url: ""
tail_tls_config:
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
query_range:
split_queries_by_interval: 0s
align_queries_with_step: false
results_cache:
cache:
enable_fifocache: true
default_validity: 1h0m0s
background:
writeback_goroutines: 10
writeback_buffer: 10000
writeback_size_limit: 1GB
memcached:
expiration: 0s
batch_size: 1024
parallelism: 100
memcached_client:
host: ""
service: memcached
addresses: ""
timeout: 100ms
max_idle_conns: 16
max_item_size: 0
update_interval: 1m0s
consistent_hash: true
circuit_breaker_consecutive_failures: 10
circuit_breaker_timeout: 10s
circuit_breaker_interval: 10s
redis:
endpoint: ""
master_name: ""
timeout: 500ms
expiration: 0s
db: 0
pool_size: 0
username: ""
password: ""
tls_enabled: false
idle_timeout: 0s
route_randomly: false
embedded_cache:
max_size_mb: 100
ttl: 1h0m0s
fifocache:
max_size_bytes: 1GB
max_size_items: 0
ttl: 1h0m0s
validity: 0s
purgeinterval: 0s
prefix: frontend.
async_cache_write_back_concurrency: 16
async_cache_write_back_buffer_size: 500
compression: ""
cache_results: false
max_retries: 5
parallelise_shardable_queries: true
forward_headers_list: []
required_query_response_format: json
cache_index_stats_results: false
index_stats_results_cache:
cache:
background:
memcached:
expiration: 0s
batch_size: 1024
parallelism: 100
memcached_client:
host: ""
service: memcached
addresses: ""
timeout: 100ms
max_idle_conns: 16
max_item_size: 0
redis:
endpoint: ""
master_name: ""
timeout: 500ms
expiration: 0s
db: 0
pool_size: 0
username: ""
password: ""
tls_enabled: false
idle_timeout: 0s
embedded_cache:
max_size_mb: 100
ttl: 1h0m0s
fifocache:
max_size_bytes: 1GB
max_size_items: 0
ttl: 1h0m0s
validity: 0s
purgeinterval: 0s
prefix: frontend.
compression: ""
ruler:
external_url: ""
datasource_uid: ""
ruler_client:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
connect_timeout: 5s
evaluation_interval: 1m0s
poll_interval: 1m0s
storage:
type: s3
azure:
environment: AzureGlobal
account_name: ""
account_key: ""
container_name: loki
endpoint_suffix: ""
use_managed_identity: false
use_federated_token: false
user_assigned_id: ""
use_service_principal: false
client_id: ""
client_secret: ""
tenant_id: ""
chunk_delimiter: '-'
download_buffer_size: 512000
upload_buffer_size: 256000
upload_buffer_count: 1
request_timeout: 30s
max_retries: 5
min_retry_delay: 10ms
max_retry_delay: 500ms
alibabacloud:
bucket: ""
endpoint: ""
access_key_id: ""
secret_access_key: ""
gcs:
bucket_name: ""
service_account: ""
chunk_buffer_size: 0
request_timeout: 0s
enable_opencensus: true
enable_http2: true
s3:
s3: s3://my-region/my-buclet.loki-rules
s3forcepathstyle: false
bucketnames: ""
endpoint: ""
region: ""
access_key_id: ""
session_token: ""
insecure: false
sse_encryption: false
http_config:
timeout: 0s
idle_conn_timeout: 1m30s
response_header_timeout: 0s
ca_file: ""
signature_version: v4
storage_class: STANDARD
sse:
type: ""
kms_key_id: ""
kms_encryption_context: ""
backoff_config:
min_period: 100ms
max_period: 3s
max_retries: 5
bos:
bucket_name: ""
endpoint: bj.bcebos.com
access_key_id: ""
swift:
auth_version: 0
auth_url: ""
internal: false
username: ""
user_domain_name: ""
user_domain_id: ""
user_id: ""
password: ""
domain_id: ""
domain_name: ""
project_id: ""
project_name: ""
project_domain_id: ""
project_domain_name: ""
region_name: ""
container_name: ""
max_retries: 3
connect_timeout: 10s
request_timeout: 5s
cos:
bucketnames: ""
endpoint: ""
region: ""
access_key_id: ""
http_config:
backoff_config:
min_period: 100ms
max_period: 3s
max_retries: 5
api_key: ""
service_instance_id: ""
auth_endpoint: https://iam.cloud.ibm.com/identity/token
cr_token_file_path: ""
trusted_profile_name: ""
trusted_profile_id: ""
local:
directory: ""
enable_alertmanager_discovery: false
alertmanager_refresh_interval: 1m0s
notification_queue_capacity: 10000
notification_timeout: 10s
alertmanager_client:
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
basic_auth_username: ""
basic_auth_password: ""
type: Bearer
for_outage_tolerance: 1h0m0s
for_grace_period: 10m0s
resend_delay: 1m0s
enable_sharding: false
sharding_strategy: default
sharding_algo: by-group
search_pending_for: 5m0s
ring:
kvstore:
store: inmemory
prefix: rulers/
consul:
acl_token: ""
watch_rate_limit: 1
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_timeout: 2s
- eth0
- lo
instance_port: 0
num_tokens: 128
flush_period: 1m0s
enable_api: true
enabled_tenants: ""
disabled_tenants: ""
disable_rule_group_label: false
wal:
tenant: ""
remotewrite: []
dir: ruler-wal
truncate_frequency: 1h0m0s
min_age: 5m0s
max_age: 4h0m0s
wal_cleaner:
min_age: 12h0m0s
deprecatedperiod: 0s
remote_write:
enabled: false
config_refresh_period: 10s
evaluation:
mode: local
max_jitter: 0s
ingester_client:
pool_config:
client_cleanup_period: 15s
health_check_ingesters: true
remote_timeout: 1s
remote_timeout: 5s
grpc_client_config:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
connect_timeout: 5s
ingester:
lifecycler:
ring:
kvstore:
store: inmemory
prefix: collectors/
consul:
acl_token: ""
watch_rate_limit: 1
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_timeout: 2s
excluded_zones: ""
num_tokens: 128
observe_period: 0s
join_after: 0s
min_ready_duration: 15s
interface_names:
- eth0
- lo
enable_inet6: false
final_sleep: 0s
unregister_on_shutdown: true
readiness_check_ring_health: true
address: 127.0.0.1
port: 0
concurrent_flushes: 32
flush_check_period: 30s
flush_op_timeout: 10m0s
chunk_retain_period: 0s
chunk_idle_period: 30m0s
chunk_block_size: 262144
chunk_target_size: 1572864
max_chunk_age: 2h0m0s
autoforget_unhealthy: false
sync_period: 0s
sync_min_utilization: 0
max_returned_stream_errors: 10
query_store_max_look_back_period: 2h41m0s
wal:
enabled: true
dir: /loki/wal
checkpoint_duration: 5m0s
flush_on_shutdown: false
replay_memory_ceiling: 4GB
index_shards: 32
max_dropped_streams: 10
shutdown_marker_path: /loki
index_gateway:
mode: simple
ring:
kvstore:
store: inmemory
prefix: collectors/
consul:
acl_token: ""
watch_rate_limit: 1
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_timeout: 2s
- eth0
- lo
instance_port: 0
storage_config:
alibabacloud:
bucket: ""
endpoint: ""
access_key_id: ""
aws:
dynamodb:
dynamodb_url: ""
api_limit: 2
throttle_limit: 10
metrics:
url: ""
target_queue_length: 100000
scale_up_factor: 1.3
ignore_throttle_below: 1
queue_length_query: sum(avg_over_time(cortex_ingester_flush_queue_length{job="cortex/ingester"}[2m]))
write_throttle_query: sum(rate(cortex_dynamo_throttled_total{operation="DynamoDB.BatchWriteItem"}[1m]))
by (table) > 0
write_usage_query: sum(rate(cortex_dynamo_consumed_capacity_total{operation="DynamoDB.BatchWriteItem"}[15m]))
by (table) > 0
read_usage_query: sum(rate(cortex_dynamo_consumed_capacity_total{operation="DynamoDB.QueryPages"}[1h]))
by (table) > 0
read_error_query: sum(increase(cortex_dynamo_failures_total{operation="DynamoDB.QueryPages",error="ProvisionedThroughputExceededException"}[1m]))
by (table) > 0
chunk_gang_size: 10
chunk_get_max_parallelism: 32
backoff_config:
min_period: 100ms
max_period: 50s
max_retries: 20
kms_key_id: ""
bucketnames: my-buclet
endpoint: ""
region: my-region
access_key_id: ""
session_token: ""
insecure: false
http_config:
timeout: 0s
ca_file: ""
sse:
type: ""
kms_key_id: ""
backoff_config:
min_period: 100ms
max_period: 3s
max_retries: 5
azure:
account_name: ""
account_key: ""
endpoint_suffix: ""
client_id: ""
client_secret: ""
tenant_id: ""
max_retries: 5
bos:
bucket_name: ""
access_key_id: ""
bigtable:
project: ""
instance: ""
grpc_client_config:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: true
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
connect_timeout: 5s
table_cache_enabled: true
table_cache_expiration: 30m0s
gcs:
bucket_name: ""
service_account: ""
request_timeout: 0s
enable_http2: true
cassandra:
addresses: ""
port: 9042
keyspace: ""
consistency: QUORUM
replication_factor: 3
disable_initial_host_lookup: false
SSL: false
host_verification: true
host_selection_policy: round-robin
CA_path: ""
tls_cert_path: ""
tls_key_path: ""
auth: false
username: ""
password: ""
password_file: ""
custom_authenticators: []
timeout: 2s
connect_timeout: 5s
reconnect_interval: 1s
max_retries: 0
retry_max_backoff: 10s
retry_min_backoff: 100ms
query_concurrency: 0
num_connections: 2
convict_hosts_on_failure: true
table_options: ""
boltdb:
directory: ""
filesystem:
directory: ""
swift:
auth_version: 0
auth_url: ""
internal: false
username: ""
user_domain_id: ""
user_id: ""
password: ""
domain_id: ""
domain_name: ""
project_id: ""
project_name: ""
region_name: ""
container_name: ""
max_retries: 3
request_timeout: 5s
grpc_store: {}
hedging:
at: 0s
up_to: 2
max_per_second: 5
named_stores:
aws: {}
azure: {}
bos: {}
filesystem: {}
gcs: {}
alibabacloud: {}
swift: {}
cos: {}
cos:
bucketnames: ""
endpoint: ""
region: ""
access_key_id: ""
http_config:
backoff_config:
min_period: 100ms
max_period: 3s
max_retries: 5
api_key: ""
index_cache_validity: 5m0s
index_queries_cache_config:
enable_fifocache: false
background:
memcached:
expiration: 0s
batch_size: 1024
parallelism: 100
memcached_client:
host: ""
service: memcached
addresses: ""
timeout: 100ms
max_idle_conns: 16
max_item_size: 0
redis:
endpoint: ""
master_name: ""
timeout: 500ms
expiration: 0s
db: 0
pool_size: 0
username: ""
password: ""
tls_enabled: false
idle_timeout: 0s
embedded_cache:
max_size_mb: 100
ttl: 1h0m0s
fifocache:
max_size_bytes: 1GB
max_size_items: 0
ttl: 1h0m0s
validity: 0s
purgeinterval: 0s
prefix: store.index-cache-read.
disable_broad_index_queries: false
max_parallel_get_chunk: 150
max_chunk_batch_size: 50
boltdb_shipper:
active_index_directory: ""
shared_store: ""
shared_store_key_prefix: index/
cache_location: ""
cache_ttl: 24h0m0s
resync_interval: 5m0s
query_ready_num_days: 0
index_gateway_client:
grpc_client_config:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
connect_timeout: 5s
log_gateway_requests: false
use_boltdb_shipper_as_backup: false
ingestername: 18b4ed97d8b9
mode: RW
ingesterdbretainperiod: 20m0s
build_per_tenant_index: false
tsdb_shipper:
shared_store: s3
cache_ttl: 24h0m0s
grpc_client_config:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
connect_timeout: 5s
mode: RW
enable_postings_cache: false
chunk_store_config:
chunk_cache_config:
background:
memcached:
expiration: 0s
batch_size: 1024
parallelism: 100
memcached_client:
host: ""
service: memcached
addresses: ""
timeout: 100ms
max_idle_conns: 16
max_item_size: 0
redis:
endpoint: ""
master_name: ""
timeout: 500ms
expiration: 0s
db: 0
pool_size: 0
username: ""
password: ""
tls_enabled: false
idle_timeout: 0s
embedded_cache:
max_size_mb: 100
ttl: 1h0m0s
fifocache:
max_size_bytes: 1GB
max_size_items: 0
ttl: 1h0m0s
validity: 0s
purgeinterval: 0s
prefix: store.chunks-cache.
chunk_cache_config_l2:
background:
memcached:
expiration: 0s
batch_size: 1024
parallelism: 100
memcached_client:
host: ""
service: memcached
addresses: ""
timeout: 100ms
max_idle_conns: 16
max_item_size: 0
redis:
endpoint: ""
master_name: ""
timeout: 500ms
expiration: 0s
db: 0
pool_size: 0
username: ""
password: ""
tls_enabled: false
idle_timeout: 0s
embedded_cache:
max_size_mb: 100
ttl: 1h0m0s
fifocache:
max_size_bytes: 1GB
max_size_items: 0
ttl: 1h0m0s
validity: 0s
purgeinterval: 0s
prefix: experimental.store.chunks-cache-l2.
write_dedupe_cache_config:
background:
memcached:
expiration: 0s
batch_size: 1024
parallelism: 100
memcached_client:
host: ""
service: memcached
addresses: ""
timeout: 100ms
max_idle_conns: 16
max_item_size: 0
redis:
endpoint: ""
master_name: ""
timeout: 500ms
expiration: 0s
db: 0
pool_size: 0
username: ""
password: ""
tls_enabled: false
idle_timeout: 0s
embedded_cache:
max_size_mb: 100
ttl: 1h0m0s
fifocache:
max_size_bytes: 1GB
max_size_items: 0
ttl: 1h0m0s
validity: 0s
purgeinterval: 0s
prefix: store.index-cache-write.
l2_chunk_cache_handoff: 0s
cache_lookups_older_than: 0s
max_look_back_period: 0s
schema_config:
configs:
store: tsdb
object_store: s3
schema: v13
index:
prefix: index_
period: 1d
tags: {}
chunks:
prefix: ""
period: 0s
tags: {}
row_shards: 16
compactor:
shared_store: s3
compaction_interval: 10m0s
apply_retention_interval: 0s
retention_enabled: false
retention_delete_delay: 2h0m0s
retention_delete_worker_count: 150
retention_table_timeout: 0s
delete_request_store: ""
delete_batch_size: 70
delete_request_cancel_period: 24h0m0s
delete_max_interval: 0s
max_compaction_parallelism: 1
upload_parallelism: 10
compactor_ring:
kvstore:
store: inmemory
prefix: collectors/
consul:
acl_token: ""
watch_rate_limit: 1
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_timeout: 2s
- eth0
- lo
instance_port: 0
_: false
tables_to_compact: 0
skip_latest_n_tables: 0
deletion_mode: ""
compactor_grpc_client:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
connect_timeout: 5s
limits_config:
ingestion_rate_strategy: global
reject_old_samples_max_age: 1w
creation_grace_period: 10m
max_line_size: 0B
max_line_size_truncate: false
increment_duplicate_timestamp: false
max_streams_per_user: 0
max_global_streams_per_user: 5000
unordered_writes: true
per_stream_rate_limit: 5MB
per_stream_rate_limit_burst: 15MB
max_chunks_per_query: 2000000
max_query_series: 500
max_query_lookback: 0s
max_query_length: 30d1h
max_query_range: 0s
max_query_parallelism: 32
tsdb_max_query_parallelism: 512
tsdb_max_bytes_per_shard: 600MB
cardinality_limit: 100000
max_streams_matchers_per_query: 1000
max_concurrent_tail_requests: 10
max_stats_cache_freshness: 0s
max_queriers_per_tenant: 0
query_ready_index_num_days: 0
query_timeout: 5m50s
split_queries_by_interval: 1d
min_sharding_lookback: 0s
max_query_bytes_read: 0B
max_querier_bytes_read: 0B
volume_enabled: false
volume_max_series: 1000
ruler_evaluation_delay_duration: 0s
ruler_max_rules_per_rule_group: 0
ruler_max_rule_groups_per_tenant: 0
ruler_alertmanager_config: null
ruler_tenant_shard_size: 0
ruler_remote_write_disabled: false
ruler_remote_write_url: ""
ruler_remote_write_timeout: 0s
ruler_remote_write_headers: {}
ruler_remote_write_queue_capacity: 0
ruler_remote_write_queue_min_shards: 0
ruler_remote_write_queue_max_shards: 0
ruler_remote_write_queue_max_samples_per_send: 0
ruler_remote_write_queue_batch_send_deadline: 0s
ruler_remote_write_queue_min_backoff: 0s
ruler_remote_write_queue_max_backoff: 0s
ruler_remote_write_queue_retry_on_ratelimit: false
ruler_remote_write_sigv4_config: null
ruler_remote_evaluation_timeout: 0s
ruler_remote_evaluation_max_response_size: 0
deletion_mode: filter-and-delete
retention_period: 90d
per_tenant_override_config: ""
per_tenant_override_period: 10s
allow_deletes: false
shard_streams:
enabled: false
logging_enabled: false
desired_rate: 3MB
index_gateway_shard_size: 1
frontend_worker:
frontend_address: ""
dns_lookup_duration: 3s
parallelism: 10
match_max_concurrent: true
grpc_client_config:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
connect_timeout: 5s
table_manager:
throughput_updates_disabled: false
retention_deletes_enabled: false
retention_period: 0s
poll_interval: 2m0s
creation_grace_period: 10m0s
index_tables_provisioning:
enable_ondemand_throughput_mode: false
provisioned_write_throughput: 1000
provisioned_read_throughput: 300
write_scale:
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
read_scale:
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
enable_inactive_throughput_on_demand_mode: false
inactive_write_throughput: 1
inactive_read_throughput: 300
inactive_write_scale:
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
inactive_read_scale:
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
inactive_write_scale_lastn: 4
inactive_read_scale_lastn: 4
chunk_tables_provisioning:
write_scale:
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
read_scale:
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
memberlist:
node_name: ""
randomize_node_name: true
stream_timeout: 10s
retransmit_factor: 4
pull_push_interval: 30s
gossip_interval: 200ms
gossip_nodes: 3
gossip_to_dead_nodes_time: 30s
dead_node_reclaim_time: 0s
compression_enabled: true
advertise_addr: ""
advertise_port: 7946
cluster_label: ""
cluster_label_verification_disabled: false
join_members: []
min_join_backoff: 1s
max_join_backoff: 1m0s
max_join_retries: 10
abort_if_cluster_join_fails: false
rejoin_interval: 0s
left_ingesters_timeout: 5m0s
leave_timeout: 20s
message_history_buffer_bytes: 0
bind_addr: []
bind_port: 7946
packet_dial_timeout: 2s
packet_write_timeout: 5s
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
runtime_config:
period: 10s
file: ""
tracing:
enabled: true
analytics:
usage_stats_url: https://stats.grafana.org/loki-usage-report
legacy_read_target: true
common:
path_prefix: /loki
storage:
s3:
s3: ""
bucketnames: ""
endpoint: ""
region: ""
access_key_id: ""
session_token: ""
insecure: false
http_config:
timeout: 0s
ca_file: ""
sse:
type: ""
kms_key_id: ""
backoff_config:
min_period: 100ms
max_period: 3s
max_retries: 5
gcs:
bucket_name: ""
service_account: ""
request_timeout: 0s
enable_http2: true
azure:
account_name: ""
account_key: ""
endpoint_suffix: ""
client_id: ""
client_secret: ""
tenant_id: ""
max_retries: 5
alibabacloud:
bucket: ""
endpoint: ""
access_key_id: ""
bos:
bucket_name: ""
access_key_id: ""
swift:
auth_version: 0
auth_url: ""
internal: false
username: ""
user_domain_id: ""
user_id: ""
password: ""
domain_id: ""
domain_name: ""
project_id: ""
project_name: ""
region_name: ""
container_name: ""
max_retries: 3
request_timeout: 5s
filesystem:
chunks_directory: ""
rules_directory: ""
hedging:
at: 0s
up_to: 2
max_per_second: 5
cos:
bucketnames: ""
endpoint: ""
region: ""
access_key_id: ""
http_config:
backoff_config:
min_period: 100ms
max_period: 3s
max_retries: 5
api_key: ""
persist_tokens: false
ring:
kvstore:
store: inmemory
prefix: collectors/
consul:
acl_token: ""
watch_rate_limit: 1
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_timeout: 2s
- eth0
- lo
instance_port: 0
- eth0
instance_addr: ""
compactor_address: ""
compactor_grpc_address: ""
shutdown_delay: 0s
Hope it helps.
Also, if I check the rules at /loki/api/v1/rules there shows
no rule groups found
and rules are in Grafana:
But still, this doesn’t answer why Grafana requires Loki to have shared storage for the ruler to enable alert history, when the rules are managed by Grafana itself
I still don’t see retention enabled in your configuration. At this point I am not sure why compactor is trying to apply retention when it’s not enabled. Are you using simple scalable mode?
This could be why Grafana is trying to hit your ruler:
This is part of the data source configuration. If you enable this whenever you open up Grafana’s alert view it’ll try to connect to Loki ruler. You can disable it then Grafana should not try to connect to your ruler anymore.
