Hi Grafana Community,
I’m currently using Grafana with Loki and I have a log line that looks like this:
Grafana version - Version 8.0.0
Loki version - loki, version HEAD-1b627d8 (branch: HEAD, revision: 1b627d880)
go version: go1.19.2
platform: linux/amd64
Sample log line
12345 12000 root S 130m 1x.1 x 0.x /usr/p1; 4444 1 root S 111m 11.x 1 x.x /usr/p2; ...
This log is ingested as a single log line representing top 10 CPU-consuming processes in a semicolon-separated format. Each entry includes fields like PID, PPID, USER, STATE, MEMORY, CPU%, CORE, IO, and COMMAND.
My goal is to:
- Display this log line as a real-time table panel in Grafana.
- Show only the most recent log entry in the panel.
- Split each process entry into a row and its fields into table columns (like PID, CPU%, Command, etc.)
What I’ve Tried:
- Using
tablepanel withFields > Transformsettings. - Tried different LogQL queries and transformation plugins like
Parse,Extract Fields,Reduce, andOuter Join. - Explored
DataFramesandLabels to Fieldsbut unable to split and map each process properly. - I’m using Loki version < 2.8, so I cannot use
unwrap.
Configuration:
- Loki deployed via Docker/systemd.
- Promtail is sending logs from a local file.
- Logs are ingested correctly but table transformation doesn’t work as expected.
Any advice on how I can:
- Parse these semicolon-separated process records?
- Display them in a table showing only the latest log line?
- Whether any plugin or newer Loki version (≥2.8) with
unwrapwould help?
Thank you!
