Grafana 8.0.6 – Centos 7 -
Get past login screen. -
user http request port 3200–> minikube → node: http-proxy to gateway → node-proxy to docker on port 9092 (Gateway X – referred to later) → grafana -
What happened?
I can request the web page to login, and it is delivered to the client (log seen in grafana-sever). When populating the form for admin / admin in firefox and “Login”, it hangs on “Logging in…” and a POST is seen in firefox developer, and is also seen at Gateway X. There is no log generated in grafana that it ever received it.
A curl command does reach grafana and shows “Login Sucessful”:
curl -d “user=admin&password=admin” -X POST http://172.17.0.2:32000/grafana/login
(this passes through the same infrastructure to reach grafana as the browser request)
Firefox to be able to login -
[server]
protocol = http
http_addr =
http_port = 9092
domain = localhost
enforce_domain = false
root_url = %(protocol)s://%(domain)s:%(http_port)s/grafana
serve_from_sub_path = true
enable_gzip = true
read_timeout = 0 -
This is displayed in the logs AFTER I refresh / navigate away
No
