Logfmt syntax error
Is there is some solution to get rid of such error:
logfmt syntax error at pos 109 : unexpected ‘=’
Log message example:
Opened file /abc/data/temp/A20230425.1645+0300-1700+0300_Network=ss-abx2-pcx-1,ManagedElement=lcp-1
loki
  1. What are you trying to do?
  2. There are other parsers besides logfmt, might want to look at the documentation and see if one fits this use case.
Solved by removing “logfmt”
