I’m trying to follow Log queries | Grafana Labs to create my own parser pattern and I’m stuck. The line which I try to parse:
2021-09-28T06:50:55.867 harvester chia.harvester.harvester: ERROR Error using prover object badbit or failbit after reading size 7421 at position 50005527089
For a test, I want to parse just the date and for this I’ve constructed this querry:
{job="logg"}|="WARNING" | pattern "<date>T<_>" | line_format "{{.date}}"
and the error which I encountered:
“parse error at line 1, col 35: syntax error: unexpected STRING”
I’m a little bit confused as I tried to follow documentation step by step. Any suggestions what did I wrong?
