First I do a fairly crude search for errors from one application (using cut to reduce line length):
$ logcli --addr=“``http://172.16.255.18:3100/”`` query --from=“2025-08-14T16:00:00Z” --to=“2025-08-28T00:00:00Z” --limit=2 '{app=“Rabbit”} |= “Address format errors” ’ | cut -c-170
2025/08/15 10:54:37 ``http://172.16.255.18:3100/loki/api/v1/query_range?direction=BACKWARD&end=1756339200000000000&limit=2&query={app%3D"Rabbit"}+|%3D+“Address+format+errors”+&start=1755187200000000000
2025/08/15 10:54:37 Common labels: {app=“Rabbit”, channel=“Rabbit”, detected_level=“error”, host=“Rabbit”, service_name=“Rabbit”}
2025-08-15T03:08:07+10:00 {} {“message”:“Address format errors”,“level”:400,“level_name”:“ERROR”,“channel”:“Rabbit”,“datetime”:“2025-08-15T03:08:07.209321+10:00”,"ctxt_pa
2025-08-15T03:08:05+10:00 {} {“message”:“Address format errors”,“level”:400,“level_name”:“ERROR”,“channel”:“Rabbit”,“datetime”:“2025-08-15T03:08:05.383036+10:00”,"ctxt_pa
Since those both have the label detected_level=”error”, I would expect to find them with:
$ logcli --addr=“``http://172.16.255.18:3100/”`` query --from=“2025-08-14T16:00:00Z” --to=“2025-08-28T00:00:00Z” --limit=2 '{app=“Rabbit”, detected_level=“error”} |= “Address format errors” ’ | cut -c-170
2025/08/15 10:56:55 ``http://172.16.255.18:3100/loki/api/v1/query_range?direction=BACKWARD&end=1756339200000000000&limit=2&query={app%3D"Rabbit"%2C+detected_level%3D"error"}+|%3D+“Address+format+errors”+&start=1755187200000000000
but that query returns no output. Why does adding the second label criterion cause the search to return nothing, when both results from the first search have that label value?
Loki 3.3.0-r5 running in an Alpine LXC on Proxmox.
