yaytay
1
This query returns the single row that I expect:
logcli -q query '{container="cms-api",namespace="building-blocks"} |= "4b7f5f1dcacb9005"' -o jsonl | grep getAll
but this does not:
logcli -q query '{namespace="building-blocks"} |= "4b7f5f1dcacb9005"' -o jsonl | grep getAll
The only difference is removing the filter on the container label.
Am I missing something?
$ logcli --version
logcli, version 2.2.1 (branch: HEAD, revision: babea82e)
build user: root@e2d295b84e26
build date: 2021-04-06T00:52:41Z
go version: go1.15.3
platform: linux/amd64
Thanks
Jim
yaytay
2
Ah, I’ve just worked it out.
It needs --limit to be set (after “query”).
This works:
logcli -q query --limit 100 '{namespace="building-blocks"} |= "4b7f5f1dcacb9005"' -o jsonl | grep getAll
and this also works:
logcli -q query '{namespace="building-blocks"} |= "4b7f5f1dcacb9005" |= "getAll"' -o jsonl
Hi @yaytay
Glad you worked it out!
So I assume, the problem was without --limit, that particular row you were interested in was not visible.
Can you mark this as resolved? Thanks!
system
Closed
4
