Using logcli to batch query result
    Latest version on window
    I want to be able to export logs above the limit of 5000
    I installed logcli on my local system, but I need help to connect it to the Grafana environment and how to run queries from logcli to batch the query result (Example query with batch instruction is required)
  • What happened?
    I need to be able to run query from my local machine with logcli and the result of query batched
    No
  • Did you follow any online instructions? If so, what is the URL? No, I cant find one that explain logcli
