/loki/api/v1/series?match api request result problem
Hello, everyone! The grafana (9.3.8) and loki (2.7.4) we used encountered some problems when querying the log labels(label browser → select labels) in Grafana Explore.
From the documentation, the time range of Grafana query labels is 1 hour, but the results obtained by Grafana Explore (Loki API) in 1 hour are inconsistent. What causes this?
We have tried grafana 9.1.x -9.4.x version, so guessing should be Loki problem (we upgraded Loki last week, from 2.4.2-> 2.7.4). The related screenshots are as follows.
Why did labels change after a period of time? (within 1 hour)
==> this is first request match lables (grafana explore)
==> this is first request match labels (loki api)
*** new user restrictions, the second request screenshot is below ***
==> this is second request (loki api)
What’s your configuration for max_chunk_age and query_ingesters_within?
I’ve not noticed this myself, what level of inconsistencies have you noticed? How many labels and potential label values do you have roughly?
Hello, thank you for your reply. Our max_chunk_age and query_ingsters_within configuration is default.
We only have about 20 label_values. In addition, we also noticed that this github issue seems to be similar to it.
The following is the loki configuration we use (run in single-node Pod).
loki.yaml
target: all
auth_enabled: true
server:
http_listen_port: 3100
grpc_listen_port: 9095
http_server_read_timeout: 120s # default: 30s
http_server_write_timeout: 120s # default: 30s
http_server_idle_timeout: 300s # default: 120s
grpc_server_max_recv_msg_size: 8388608 # default: 4194304
grpc_server_max_send_msg_size: 8388608 # default: 4194304
grpc_server_max_concurrent_streams: 200 # default: 100
log_level: warn # default: info
querier:
tail_max_duration: 30m # default: 1h
max_concurrent: 6 # default: 10
multi_tenant_queries_enabled: false # default: false
engine:
max_look_back_period: 60s # default: 30s
query_scheduler:
max_outstanding_requests_per_tenant: 200 # default: 100
querier_forget_delay: 1m # default: 0s
frontend:
max_outstanding_per_tenant: 200 # default: 100
query_range:
max_retries: 3 # default: 5
parallelise_shardable_queries: false # default: true
ingester:
lifecycler:
address: 127.0.0.1
ring:
kvstore:
store: inmemory
heartbeat_timeout: 1m
replication_factor: 1 # default: 3
heartbeat_period: 5s
interface_names: [ “eth0”, “en0”, “ens33”, “ens160” ]
final_sleep: 0s # default: 30s
chunk_retain_period: 30s # default: 0s
chunk_idle_period: 5m # default: 30m
wal:
enabled: true
dir: /data/wal
flush_on_shutdown: true # default: false
replay_memory_ceiling: 1GB # default: 4GB
storage_config:
boltdb_shipper:
active_index_directory: /data/index
shared_store: filesystem
cache_location: /data/index_cache
cache_ttl: 24h
resync_interval: 5m
query_ready_num_days: 0
filesystem:
directory: /data/chunks
index_cache_validity: 5m
max_chunk_batch_size: 50
schema_config:
configs:
    store: boltdb-shipper
    object_store: filesystem
    schema: v11
    index:
    prefix: index_
    period: 24h # default: 168h
    chunks:
    period: 168h
    row_shards: 16
compactor:
working_directory: /data/compactor
retention_enabled: true # default: false
retention_delete_delay: 10m # default: 2h
retention_delete_worker_count: 150
delete_request_cancel_period: 1h # default: 24h
limits_config:
ingestion_rate_strategy: global
split_queries_by_interval: 10m # default: 30m
query_timeout: 10m # default: 1m
ingestion_rate_mb: 40 # default: 4
ingestion_burst_size_mb: 60 # default: 6
enforce_metric_name: false # default: true
max_entries_limit_per_query: 10000 # default: 5000
deletion_mode: filter-and-delete
table_manager:
retention_deletes_enabled: true # default: false
retention_period: 17280h # default: 0
We tried to further understand the working principles and configurations of each component in Loki, and then conducted tests. We found that the issue seemed to be related to our chunk_idle_period configuration. Our development and testing environments have fewer log streams, it was easy for us to reach the chunk_idle_period(5m), which caused chunk flushing (perhaps for this reason). Now we have adjusted it to 1h, and the query label values meet our expectations.
During our understanding of Loki components and testing process, we found that some previous configurations were incorrect. Therefore, adjustments were made based on our actual environment, and now our configuration is as follows, running well.
loki.yaml
target: all
auth_enabled: true
server:
http_listen_port: 3100 # default: 80
grpc_listen_port: 9095 # default: 9095
graceful_shutdown_timeout: 30s # default: 30s
grpc_server_max_concurrent_streams: 1000 # default: 100
common:
path_prefix: /data
ring:
kvstore:
store: inmemory
heartbeat_period: 15s
limits_config:
reject_old_samples: true
max_global_streams_per_user: 10000 # default: 5000
unordered_writes: true
max_query_length: 2161h # default: 721h
max_query_series: 5000 # default: 500
max_streams_matchers_per_query: 1000
max_cache_freshness_per_query: 10m # default: 1m
max_query_lookback: 2160h # default: 0
split_queries_by_interval: 15m # default: 30m
query_timeout: 10m # default: 5m
retention_period: 8784h # default: 744h
ingester_client:
pool_config:
health_check_ingesters: false
client_cleanup_period: 15s
ingester:
lifecycler:
final_sleep: 5s # default: 0s
chunk_idle_period: 1h # default: 30m
max_chunk_age: 2h
autoforget_unhealthy: false
wal:
enabled: true
flush_on_shutdown: false
frontend:
max_outstanding_per_tenant: 1024 # default: 2048
log_queries_longer_than: 0s
query_scheduler:
max_outstanding_requests_per_tenant: 512 # default: 100
use_scheduler_ring: true # default: false
query_range:
align_queries_with_step: true # default: false
cache_results: true # default: false
results_cache:
cache:
enable_fifocache: false # default: true
default_validity: 1h
embedded_cache:
max_size_mb: 256 # default: 100
ttl: 1h
querier:
query_ingesters_within: 2h # default: 3h
max_concurrent: 10
query_store_only: false
query_ingester_only: false
multi_tenant_queries_enabled: true # default: false
chunk_store_config:
chunk_cache_config:
embedded_cache:
enabled: true
max_size_mb: 100
ttl: 1h
write_dedupe_cache_config:
embedded_cache:
enabled: true
max_size_mb: 100
ttl: 1h
schema_config:
configs:
    schema: v11
    index:
    prefix: index_
    period: 24h
    chunks:
    period: 168h
storage_config:
boltdb_shipper:
active_index_directory: /data/index # default: boltdb-shipper-active
cache_location: /data/index_cache # default: boltdb-shipper-cache
cache_ttl: 24h
filesystem:
index_queries_cache_config:
embedded_cache:
enabled: true
max_size_mb: 100
ttl: 1h
compactor:
table_manager:
retention_period: 8784h # default: 0
