- What is your Grafana version?
v8.3.4 - Are you using Grafana Cloud or self-hosted Grafana?
Self Hosted
I am having trouble to build a panel using ‘logs’ visualization.
My input data is this API- https://my-json-server.typicode.com/avikkumar1983/fakeapi/db
My plugin for datasource is - JSON API https://grafana.com/grafana/plugins/marcusolsson-json-datasource/
I am able to plot the data using ‘table’ visualization as below.
But whenever I am trying ‘logs visualization its’ going blank.
I am able to build log visualization from ‘cloudwatch logs’, which is also a JSON format data. So is there any specific format to build log visualization from API or it’s not possible currently.
