Log kubernetes pod events into grafana with loki
Hello All,
i am trying to log all the kubernetes events like pod restarts are etc which is basically
kubectl get events
from all the namsespaces…
Can someone guide how to proceed further… i am experimenting with helm chat of grafana-loki and tried these scrape configs. but still i could see the {job: kubernetes_events}
  - job_name: kubernetes-events
          kubernetes_sd_configs:
            - role: node
          relabel_configs:
            - action: replace
              source_labels:
                - __meta_kubernetes_node_name
              target_label: node_name
            - action: replace
              source_labels:
                - __address__
              target_label: __address__
              regex: (.+):(.+)
              replacement: ${1}:10250
          scrape_configs:
                - role: node
              metrics_path: /api/v1/events
              params:
                fieldSelector: [involvedObject.namespace!=""]
              bearer_token_file: /var/run/secrets/kubernetes.io/serviceaccount/token
              tls_config:
                ca_file: /var/run/secrets/kubernetes.io/serviceaccount/ca.crt
                insecure_skip_verify: true
