Hi, does anyone know if it is possible to lock the global variables selected by the user from the filters across all the dashboards? Thank you.
Hello
What do you mean by locking it?
Hello, thanks for your response.
What I meant by locking is when the user select a field on the dropdown filter for the dashboard. I want to save this selected field and apply to all the other dashboards. So that, when the user opens another dashboard, the selected field will remain the same. Thank you.
