v8.3.4 -
Load on docker up alerts -
I use a docker-compose file to build up my monitoring setup. Therefore I have a folder with json dashboards and grafana.ini and prometheus.ini etc… These files and folders are mounted to the docker setup.
Now I created alarms but when I switch e.g my monitoring machine or clear grafana settings withdocker-compose down -vthe alerts are removed. -
I expect exactly this, but asking for a way to mount an alert.json or folder to read in alerts on docker-compose up.
Looking for a way to persist the alerts. I’m backuping the whole setup on my private git.
Thanks
