Grafana 9.2.3 alert feature: How to export / import alerts as yml/json?
Hi.
Is it possible to export all alerts of the Grafana 9.2.3 alerts to a json or yml file like all the other dashboards and datasources (and use it later in the provision process)?
I tried using grafana api, but it’s not returning anything.
Greetings and thanks in advance,
Faizan
Welcome
Could youbpleqse show us what you did?
I’ve tried to list alerts using below grafana api but it’s returning
curl -s -H "Authorization: Bearer api_token -X GET “https://URI/api/alerts”
hi @faizanshah
to export all alert rules in provisioning file format,
try :
/api/v1/provisioning/alert-rules/export
Hi there,
I wonder if there is also a way (Grafana 9.4) to import alerts as json.
In a same fashion as it is possible with provisioning for dashboards.
Any recommendations?
Thanks
Have you checked
Antony.
