The data source is postgresql.
I define a panel variable meter_code whose type is Textbox.
I want to do a fuzzy query on this variable:
select *
from meter
where meter_code like '%$meter_code%';
This works fine when meter_code has a value:
select *
from meter
where meter_code like '%METXJJSZXNSB1%';
When meter_code is null:
select *
from meter
where meter_code like '%%';
This is not the result I want, I hope it should be:
select *
from meter
Please, what should I do? Thanks!
its not really a grafana issue but that said try
select *
from meter
where $meter_code is null
or meter_code like '%$meter_code%';
Very good, I think this is a way to solve the problem.
I wonder if it’s possible to automatically omit the following SQL statement like ‘=’ if the value is null
what do you mean by that?
select *
from meter
where meter_code = $meter_code;
If $meter_code is null
So the Grafana execution statement is:
select *
from meter
Grafana will automatically ignore the ‘where’ section
Grafana shouldn’t do that. Its job is to replace template variable with value, apart from that it’s a query responsibility to consider different possible cases.
I think you are right, thank you for your reply!
