Hello, we are using S3 bucket for storing logs with Loki (and promtail) on our K8s cluster. We see a lot of error messages in Loki logs msg="failed to flush user".
Did we hit some S3 limitations or it’s something with configuration? We don’t have any errors on our development cluster with the same exact Loki configuration.
Thanks, any help will be appreciated.
level=error ts=2023-03-01T06:56:01.687692933Z caller=flush.go:221 org_id=fake msg="failed to flush user" err="RequestCanceled: request context canceled\ncaused by: context deadline exceeded"
level=error ts=2023-03-01T06:56:01.687737296Z caller=flush.go:221 org_id=fake msg="failed to flush user" err="RequestCanceled: request context canceled\ncaused by: context deadline exceeded"
level=error ts=2023-03-01T06:56:01.860268489Z caller=flush.go:221 org_id=fake msg="failed to flush user" err="RequestCanceled: request context canceled\ncaused by: context deadline exceeded"
Loki config: loki.yaml (grafana/loki:2.4.2)
auth_enabled: false
chunk_store_config:
max_look_back_period: 744h
compactor:
retention_enabled: true
shared_store: s3
working_directory: /data/loki/boltdb-shipper-compactor
ingester:
chunk_block_size: 262144
chunk_idle_period: 5m
chunk_retain_period: 30s
lifecycler:
ring:
kvstore:
store: inmemory
replication_factor: 1
max_chunk_age: 5m
max_transfer_retries: 0
wal:
dir: /data/loki/wal
limits_config:
enforce_metric_name: false
reject_old_samples: true
retention_period: 744h
schema_config:
configs:
index:
period: 24h
prefix: loki_index_
object_store: aws
schema: v11
store: boltdb-shipper
server:
http_listen_port: 3132
storage_config:
aws:
region: nl-ams
s3: https://ACCESS:TOKEN@s3.nl-ams.scw.cloud/bucket_name
s3forcepathstyle: true
boltdb_shipper:
active_index_directory: /data/loki/index
cache_location: /data/loki/boltdb-cache
cache_ttl: 24h
shared_store: s3
filesystem:
directory: /data/loki/chunks
table_manager:
retention_deletes_enabled: true
