Logs missing at loki,
error level=warn orgID=xyz msg="POST /loki/api/v1/push (500) 5.007729449s Response: \"rpc error: code = DeadlineExceeded desc = context deadline exceeded\\n\" ws: false; Content-Length: 301968; Content-Type: application/x-protobuf; User-Agent: promtail/; X-Scope-Orgid: xyz; "
Logs missing at loki running on microservice mode of deployment on ec2, storage index- aws dynamo chunk- aws s3
Common config for all targets
# Loki Config
# (version=2.7.3, branch=HEAD, revision=a880ea3bf)
target: all
auth_enabled: true
http_prefix: ""
ballast_bytes: 0
use_buffered_logger: true
use_sync_logger: true
common:
  path_prefix: ""
  storage:
    s3:
      s3: ""
      s3forcepathstyle: false
      bucketnames: ""
      endpoint: ""
      region: ""
      access_key_id: ""
      secret_access_key: ""
      insecure: false
      sse_encryption: false
      http_config:
        idle_conn_timeout: 1m30s
        response_header_timeout: 0s
        insecure_skip_verify: false
        ca_file: ""
      signature_version: v4
      sse:
        type: ""
        kms_key_id: ""
        kms_encryption_context: ""
      backoff_config:
        min_period: 100ms
        max_period: 3s
        max_retries: 5
    gcs:
      bucket_name: ""
      service_account: ""
      chunk_buffer_size: 0
      request_timeout: 0s
      enable_opencensus: true
      enable_http2: true
    azure:
      environment: AzureGlobal
      account_name: ""
      account_key: ""
      container_name: loki
      endpoint_suffix: ""
      use_managed_identity: false
      user_assigned_id: ""
      use_service_principal: false
      client_id: ""
      client_secret: ""
      tenant_id: ""
      chunk_delimiter: '-'
      download_buffer_size: 512000
      upload_buffer_size: 256000
      upload_buffer_count: 1
      request_timeout: 30s
      max_retries: 5
      min_retry_delay: 10ms
      max_retry_delay: 500ms
    bos:
      bucket_name: ""
      endpoint: bj.bcebos.com
      access_key_id: ""
    swift:
      auth_version: 0
      auth_url: ""
      username: ""
      user_domain_name: ""
      user_domain_id: ""
      user_id: ""
      password: ""
      domain_id: ""
      domain_name: ""
      project_id: ""
      project_name: ""
      project_domain_id: ""
      project_domain_name: ""
      region_name: ""
      container_name: ""
      max_retries: 3
      connect_timeout: 10s
      request_timeout: 5s
    filesystem:
      chunks_directory: ""
      rules_directory: ""
    hedging:
      at: 0s
      up_to: 2
      max_per_second: 5
  persist_tokens: false
  replication_factor: 3
  ring:
    kvstore:
      store: consul
      prefix: collectors/
      consul:
        host: localhost:8500
        acl_token: ""
        http_client_timeout: 20s
        consistent_reads: false
        watch_rate_limit: 1
        watch_burst_size: 1
        cas_retry_delay: 1s
      etcd:
        endpoints: []
        dial_timeout: 10s
        max_retries: 10
        tls_enabled: false
        tls_cert_path: ""
        tls_key_path: ""
        tls_ca_path: ""
        tls_server_name: ""
        tls_insecure_skip_verify: false
        tls_cipher_suites: ""
        tls_min_version: ""
        username: ""
        password: ""
      multi:
        primary: ""
        secondary: ""
        mirror_enabled: false
        mirror_timeout: 2s
    heartbeat_period: 15s
    heartbeat_timeout: 1m0s
    tokens_file_path: ""
    zone_awareness_enabled: false
    instance_id: w.x.y.z
    instance_interface_names:
    - ens5
    - eth0
    - en0
    - lo
    instance_port: 0
    instance_addr: ""
    instance_availability_zone: ""
  - ens5
  instance_addr: ""
  compactor_address: ""
  compactor_grpc_address: ""
server:
  http_listen_network: tcp
  http_listen_address: ""
  http_listen_port: 80
  http_listen_conn_limit: 0
  grpc_listen_network: tcp
  grpc_listen_address: ""
  grpc_listen_port: 9095
  grpc_listen_conn_limit: 0
  tls_min_version: ""
  http_tls_config:
    cert_file: ""
    key_file: ""
    client_auth_type: ""
    client_ca_file: ""
  grpc_tls_config:
    cert_file: ""
    key_file: ""
    client_ca_file: ""
  register_instrumentation: true
  graceful_shutdown_timeout: 30s
  http_server_read_timeout: 10m0s
  http_server_write_timeout: 10m0s
  http_server_idle_timeout: 2m0s
  grpc_server_max_recv_msg_size: 95194304
  grpc_server_max_send_msg_size: 95194304
  grpc_server_max_concurrent_streams: 100
  grpc_server_max_connection_idle: 2562047h47m16.854775807s
  grpc_server_max_connection_age: 2562047h47m16.854775807s
  grpc_server_max_connection_age_grace: 2562047h47m16.854775807s
  grpc_server_keepalive_time: 2h0m0s
  grpc_server_keepalive_timeout: 20s
  grpc_server_min_time_between_pings: 10s
  grpc_server_ping_without_stream_allowed: true
  log_format: logfmt
  log_level: info
  log_source_ips_enabled: false
  log_source_ips_header: ""
  log_source_ips_regex: ""
  log_request_at_info_level_enabled: false
  http_path_prefix: ""
internal_server:
  http_listen_address: localhost
  http_listen_port: 3101
  grpc_listen_network: ""
  grpc_listen_port: 0
  tls_min_version: ""
  http_tls_config:
    cert_file: ""
    key_file: ""
    client_ca_file: ""
  grpc_tls_config:
    cert_file: ""
    key_file: ""
    client_ca_file: ""
  register_instrumentation: false
  http_server_read_timeout: 30s
  http_server_write_timeout: 30s
  grpc_server_max_recv_msg_size: 0
  grpc_server_max_send_msg_size: 0
  grpc_server_max_concurrent_streams: 0
  grpc_server_max_connection_idle: 0s
  grpc_server_max_connection_age: 0s
  grpc_server_max_connection_age_grace: 0s
  grpc_server_keepalive_time: 0s
  grpc_server_keepalive_timeout: 0s
  grpc_server_min_time_between_pings: 0s
  grpc_server_ping_without_stream_allowed: false
  log_format: ""
  log_level: ""
  enable: false
distributor:
  ring:
    kvstore:
      store: memberlist
      prefix: collectors/
      consul:
        acl_token: ""
        watch_rate_limit: 1
        watch_burst_size: 1
        cas_retry_delay: 1s
      etcd:
        endpoints: []
        dial_timeout: 10s
        max_retries: 10
        tls_enabled: false
        tls_cert_path: ""
        tls_key_path: ""
        tls_ca_path: ""
        tls_server_name: ""
        tls_min_version: ""
        username: ""
        password: ""
      multi:
        primary: ""
        secondary: ""
        mirror_timeout: 2s
    - ens5
    - eth0
    - en0
    - lo
    instance_port: 0
    instance_addr: ""
  rate_store:
    max_request_parallelism: 200
    stream_rate_update_interval: 1s
    ingester_request_timeout: 500ms
querier:
  tail_max_duration: 1h0m0s
  query_ingesters_within: 3h0m0s
  engine:
    timeout: 5m0s
    max_look_back_period: 30s
  max_concurrent: 10
  query_store_only: false
  query_ingester_only: false
  multi_tenant_queries_enabled: true
  query_timeout: 0s
compactor_grpc_client:
  max_recv_msg_size: 104857600
  max_send_msg_size: 104857600
  grpc_compression: ""
  rate_limit: 0
  rate_limit_burst: 0
  backoff_on_ratelimits: false
  backoff_config:
    min_period: 100ms
    max_period: 10s
    max_retries: 10
  tls_enabled: false
  tls_cert_path: ""
  tls_key_path: ""
  tls_ca_path: ""
  tls_server_name: ""
  tls_min_version: ""
ingester_client:
  pool_config:
    client_cleanup_period: 15s
    health_check_ingesters: true
    remote_timeout: 1s
  remote_timeout: 5s
  grpc_client_config:
    rate_limit: 0
    rate_limit_burst: 0
    backoff_config:
      min_period: 100ms
      max_period: 10s
      max_retries: 10
    tls_enabled: false
    tls_cert_path: ""
    tls_key_path: ""
    tls_ca_path: ""
    tls_server_name: ""
    tls_min_version: ""
ingester:
  lifecycler:
    ring:
      kvstore:
        store: memberlist
        prefix: collectors/
        consul:
          acl_token: ""
          watch_rate_limit: 1
          watch_burst_size: 1
          cas_retry_delay: 1s
        etcd:
          endpoints: []
          dial_timeout: 10s
          max_retries: 10
          tls_enabled: false
          tls_cert_path: ""
          tls_key_path: ""
          tls_ca_path: ""
          tls_server_name: ""
          tls_min_version: ""
          username: ""
          password: ""
        multi:
          primary: ""
          secondary: ""
          mirror_timeout: 2s
      replication_factor: 2
      excluded_zones: ""
    num_tokens: 128
    observe_period: 0s
    join_after: 0s
    min_ready_duration: 15s
    interface_names:
    - ens5
    - eth0
    - en0
    - lo
    final_sleep: 0s
    unregister_on_shutdown: true
    readiness_check_ring_health: true
    address: ""
    port: 0
  concurrent_flushes: 32
  flush_check_period: 30s
  flush_op_timeout: 10m0s
  chunk_retain_period: 0s
  chunk_idle_period: 30m0s
  chunk_block_size: 262144
  chunk_target_size: 50000000
  chunk_encoding: snappy
  max_chunk_age: 2h0m0s
  autoforget_unhealthy: true
  sync_period: 0s
  sync_min_utilization: 0
  max_returned_stream_errors: 10
  query_store_max_look_back_period: 0s
  wal:
    enabled: true
    dir: /data
    checkpoint_duration: 5m0s
    flush_on_shutdown: false
    replay_memory_ceiling: 4294967296
  index_shards: 32
  max_dropped_streams: 10
storage_config:
  aws:
    dynamodb:
      dynamodb_url: dynamodb://ap-south-1
      api_limit: 2
      throttle_limit: 10
      metrics:
        url: ""
        target_queue_length: 100000
        scale_up_factor: 1.3
        ignore_throttle_below: 1
        queue_length_query: sum(avg_over_time(cortex_ingester_flush_queue_length{job="cortex/ingester"}[2m]))
        write_throttle_query: sum(rate(cortex_dynamo_throttled_total{operation="DynamoDB.BatchWriteItem"}[1m]))
          by (table) > 0
        write_usage_query: sum(rate(cortex_dynamo_consumed_capacity_total{operation="DynamoDB.BatchWriteItem"}[15m]))
          by (table) > 0
        read_usage_query: sum(rate(cortex_dynamo_consumed_capacity_total{operation="DynamoDB.QueryPages"}[1h]))
          by (table) > 0
        read_error_query: sum(increase(cortex_dynamo_failures_total{operation="DynamoDB.QueryPages",error="ProvisionedThroughputExceededException"}[1m]))
          by (table) > 0
      chunk_gang_size: 10
      chunk_get_max_parallelism: 32
      backoff_config:
        min_period: 100ms
        max_period: 50s
        max_retries: 20
    s3: s3://ap-south-1/loki-prod
    bucketnames: ""
    endpoint: ""
    region: ""
    access_key_id: ""
    insecure: false
    http_config:
      ca_file: ""
    sse:
      type: ""
      kms_key_id: ""
    backoff_config:
      min_period: 100ms
      max_period: 3s
      max_retries: 5
  azure:
    account_name: ""
    account_key: ""
    endpoint_suffix: ""
    client_id: ""
    client_secret: ""
    tenant_id: ""
    max_retries: 5
  bos:
    bucket_name: ""
    access_key_id: ""
  bigtable:
    project: ""
    instance: ""
    grpc_client_config:
      rate_limit: 0
      rate_limit_burst: 0
      backoff_config:
        min_period: 100ms
        max_period: 10s
        max_retries: 10
      tls_enabled: true
      tls_cert_path: ""
      tls_key_path: ""
      tls_ca_path: ""
      tls_server_name: ""
      tls_min_version: ""
    table_cache_enabled: true
    table_cache_expiration: 30m0s
  gcs:
    bucket_name: ""
    service_account: ""
    request_timeout: 0s
    enable_http2: true
  cassandra:
    addresses: ""
    port: 9042
    keyspace: ""
    consistency: QUORUM
    disable_initial_host_lookup: false
    SSL: false
    host_verification: true
    host_selection_policy: round-robin
    CA_path: ""
    tls_cert_path: ""
    tls_key_path: ""
    auth: false
    username: ""
    password: ""
    password_file: ""
    custom_authenticators: []
    timeout: 2s
    connect_timeout: 5s
    reconnect_interval: 1s
    max_retries: 0
    retry_max_backoff: 10s
    retry_min_backoff: 100ms
    query_concurrency: 0
    num_connections: 2
    convict_hosts_on_failure: true
    table_options: ""
  boltdb:
    directory: ""
  filesystem:
    directory: ""
  swift:
    auth_version: 0
    auth_url: ""
    username: ""
    user_domain_id: ""
    user_id: ""
    password: ""
    domain_id: ""
    domain_name: ""
    project_id: ""
    project_name: ""
    region_name: ""
    container_name: ""
    max_retries: 3
    request_timeout: 5s
  grpc_store: {}
  hedging:
    at: 0s
    up_to: 2
    max_per_second: 5
  index_cache_validity: 5m0s
  index_queries_cache_config:
    enable_fifocache: false
    default_validity: 1h0m0s
    background:
      writeback_goroutines: 10
      writeback_buffer: 10000
    memcached:
      expiration: 0s
      batch_size: 1024
      parallelism: 100
    memcached_client:
      host: ""
      service: memcached
      addresses: ""
      timeout: 100ms
      max_idle_conns: 16
      max_item_size: 0
      update_interval: 1m0s
      consistent_hash: true
      circuit_breaker_consecutive_failures: 10
      circuit_breaker_timeout: 10s
      circuit_breaker_interval: 10s
    redis:
      endpoint: ""
      master_name: ""
      timeout: 500ms
      expiration: 0s
      db: 0
      pool_size: 0
      username: ""
      password: ""
      tls_enabled: false
      idle_timeout: 0s
    embedded_cache:
      max_size_mb: 100
      ttl: 1h0m0s
    fifocache:
      max_size_bytes: 1GB
      max_size_items: 0
      ttl: 1h0m0s
      validity: 0s
      purgeinterval: 0s
    prefix: store.index-cache-read.
    async_cache_write_back_concurrency: 16
    async_cache_write_back_buffer_size: 500
  disable_broad_index_queries: false
  max_parallel_get_chunk: 150
  max_chunk_batch_size: 50
  boltdb_shipper:
    active_index_directory: ""
    shared_store: ""
    shared_store_key_prefix: index/
    cache_location: ""
    cache_ttl: 24h0m0s
    resync_interval: 5m0s
    query_ready_num_days: 0
    index_gateway_client:
      grpc_client_config:
        rate_limit: 0
        rate_limit_burst: 0
        backoff_config:
          min_period: 100ms
          max_period: 10s
          max_retries: 10
        tls_enabled: false
        tls_cert_path: ""
        tls_key_path: ""
        tls_ca_path: ""
        tls_server_name: ""
        tls_min_version: ""
      log_gateway_requests: false
    use_boltdb_shipper_as_backup: false
    ingestername: ""
    mode: RW
    ingesterdbretainperiod: 0s
    build_per_tenant_index: false
  tsdb_shipper:
    shared_store: ""
    cache_location: ""
    cache_ttl: 24h0m0s
      grpc_client_config:
        rate_limit: 0
        rate_limit_burst: 0
        backoff_config:
          min_period: 100ms
          max_period: 10s
          max_retries: 10
        tls_enabled: false
        tls_cert_path: ""
        tls_key_path: ""
        tls_ca_path: ""
        tls_server_name: ""
        tls_min_version: ""
    ingestername: ""
    mode: RW
index_gateway:
  mode: simple
  ring:
    kvstore:
      store: consul
      prefix: collectors/
      consul:
        acl_token: ""
        watch_rate_limit: 1
        watch_burst_size: 1
        cas_retry_delay: 1s
      etcd:
        endpoints: []
        dial_timeout: 10s
        max_retries: 10
        tls_enabled: false
        tls_cert_path: ""
        tls_key_path: ""
        tls_ca_path: ""
        tls_server_name: ""
        tls_min_version: ""
        username: ""
        password: ""
      multi:
        primary: ""
        secondary: ""
        mirror_timeout: 2s
    - ens5
    - eth0
    - en0
    - lo
    instance_port: 0
    instance_addr: ""
chunk_store_config:
  chunk_cache_config:
    enable_fifocache: true
    background:
    memcached:
      expiration: 0s
      batch_size: 1024
      parallelism: 100
    memcached_client:
      host: ""
      service: memcached
      addresses: ""
      timeout: 100ms
      max_idle_conns: 16
      max_item_size: 0
    redis:
      endpoint: ""
      master_name: ""
      timeout: 500ms
      expiration: 0s
      db: 0
      pool_size: 0
      username: ""
      password: ""
      tls_enabled: false
      idle_timeout: 0s
    embedded_cache:
      max_size_mb: 100
      ttl: 1h0m0s
    fifocache:
      max_size_bytes: 1GB
      max_size_items: 0
      ttl: 1h0m0s
      validity: 0s
      purgeinterval: 0s
    prefix: store.chunks-cache.
  write_dedupe_cache_config:
    background:
    memcached:
      expiration: 0s
      batch_size: 1024
      parallelism: 100
    memcached_client:
      host: ""
      service: memcached
      addresses: ""
      timeout: 100ms
      max_idle_conns: 16
      max_item_size: 0
    redis:
      endpoint: ""
      master_name: ""
      timeout: 500ms
      expiration: 0s
      db: 0
      pool_size: 0
      username: ""
      password: ""
      tls_enabled: false
      idle_timeout: 0s
    embedded_cache:
      max_size_mb: 100
      ttl: 1h0m0s
    fifocache:
      max_size_bytes: 1GB
      max_size_items: 0
      ttl: 1h0m0s
      validity: 0s
      purgeinterval: 0s
    prefix: store.index-cache-write.
  cache_lookups_older_than: 0s
  max_look_back_period: 14w
schema_config:
  configs:
    store: aws
    object_store: aws
    schema: v11
    index:
      prefix: loki_index_
      period: 1w
      tags:
        role: loki
    chunks:
      prefix: ""
      period: 0s
      tags: {}
    row_shards: 16
    store: aws
    object_store: aws
    schema: v12
    index:
      prefix: loki_index_
      period: 1w
      tags:
        Role: loki
    chunks:
      prefix: ""
      period: 0s
      tags: {}
    row_shards: 16
limits_config:
  ingestion_rate_strategy: local
  ingestion_rate_mb: 300
  ingestion_burst_size_mb: 30
  max_label_name_length: 1024
  max_label_value_length: 2048
  max_label_names_per_series: 30
  reject_old_samples: true
  reject_old_samples_max_age: 1w
  creation_grace_period: 10m
  enforce_metric_name: false
  max_line_size: 0
  max_line_size_truncate: false
  increment_duplicate_timestamp: false
  max_streams_per_user: 0
  max_global_streams_per_user: 50000
  unordered_writes: true
  per_stream_rate_limit: 52428800
  per_stream_rate_limit_burst: 20971520
  max_chunks_per_query: 2000000
  max_query_series: 1000
  max_query_lookback: 14w
  max_query_length: 1w
  max_query_parallelism: 32
  cardinality_limit: 10000
  max_streams_matchers_per_query: 1000
  max_concurrent_tail_requests: 10
  max_entries_limit_per_query: 10000
  max_cache_freshness_per_query: 10m
  max_queriers_per_tenant: 0
  query_ready_index_num_days: 0
  query_timeout: 5m
  split_queries_by_interval: 5m
  min_sharding_lookback: 0s
  ruler_evaluation_delay_duration: 0s
  ruler_max_rules_per_rule_group: 0
  ruler_max_rule_groups_per_tenant: 0
  ruler_alertmanager_config: null
  ruler_remote_write_disabled: false
  ruler_remote_write_url: ""
  ruler_remote_write_timeout: 0s
  ruler_remote_write_headers: {}
  ruler_remote_write_queue_capacity: 0
  ruler_remote_write_queue_min_shards: 0
  ruler_remote_write_queue_max_shards: 0
  ruler_remote_write_queue_max_samples_per_send: 0
  ruler_remote_write_queue_batch_send_deadline: 0s
  ruler_remote_write_queue_min_backoff: 0s
  ruler_remote_write_queue_max_backoff: 0s
  ruler_remote_write_queue_retry_on_ratelimit: false
  ruler_remote_write_sigv4_config: null
  deletion_mode: filter-only
  retention_period: 14w
  per_tenant_override_config: ""
  per_tenant_override_period: 10s
  allow_deletes: false
  shard_streams:
    enabled: false
    logging_enabled: false
    desired_rate: 3145728
table_manager:
  throughput_updates_disabled: true
  retention_deletes_enabled: true
  poll_interval: 2m0s
  creation_grace_period: 12h0m0s
  index_tables_provisioning:
    enable_ondemand_throughput_mode: true
    provisioned_write_throughput: 10
    provisioned_read_throughput: 70
    write_scale:
      enabled: false
      role_arn: ""
      min_capacity: 3000
      max_capacity: 6000
      out_cooldown: 1800
      in_cooldown: 1800
      target: 80
    read_scale:
      enabled: false
      role_arn: ""
      min_capacity: 3000
      max_capacity: 6000
      out_cooldown: 1800
      in_cooldown: 1800
      target: 80
    enable_inactive_throughput_on_demand_mode: false
    inactive_write_throughput: 1
    inactive_read_throughput: 30
    inactive_write_scale:
      enabled: false
      role_arn: ""
      min_capacity: 3000
      max_capacity: 6000
      out_cooldown: 1800
      in_cooldown: 1800
      target: 80
    inactive_read_scale:
      enabled: false
      role_arn: ""
      min_capacity: 0
      max_capacity: 0
      out_cooldown: 0
      in_cooldown: 0
      target: 0
    inactive_write_scale_lastn: 3
    inactive_read_scale_lastn: 4
  chunk_tables_provisioning:
    write_scale:
      enabled: false
      role_arn: ""
      min_capacity: 3000
      max_capacity: 6000
      out_cooldown: 1800
      in_cooldown: 1800
      target: 80
    read_scale:
      enabled: false
      role_arn: ""
      min_capacity: 3000
      max_capacity: 6000
      out_cooldown: 1800
      in_cooldown: 1800
      target: 80
      enabled: false
      role_arn: ""
      min_capacity: 3000
      max_capacity: 6000
      out_cooldown: 1800
      in_cooldown: 1800
      target: 80
      enabled: false
      role_arn: ""
      min_capacity: 3000
      max_capacity: 6000
      out_cooldown: 1800
      in_cooldown: 1800
      target: 80
frontend_worker:
  frontend_address: querier-fe.com:9095
  scheduler_address: ""
  dns_lookup_duration: 3s
  parallelism: 50
  match_max_concurrent: true
  grpc_client_config:
    rate_limit: 0
    rate_limit_burst: 0
    backoff_config:
      min_period: 100ms
      max_period: 10s
      max_retries: 10
    tls_enabled: false
    tls_cert_path: ""
    tls_key_path: ""
    tls_ca_path: ""
    tls_server_name: ""
    tls_min_version: ""
frontend:
  log_queries_longer_than: 0s
  max_body_size: 10485760
  query_stats_enabled: false
  max_outstanding_per_tenant: 2048
  querier_forget_delay: 0s
  scheduler_dns_lookup_period: 10s
  scheduler_worker_concurrency: 5
  grpc_client_config:
    rate_limit: 0
    rate_limit_burst: 0
    backoff_config:
      min_period: 100ms
      max_period: 10s
      max_retries: 10
    tls_enabled: false
    tls_cert_path: ""
    tls_key_path: ""
    tls_ca_path: ""
    tls_server_name: ""
    tls_min_version: ""
  - ens5
  - lo
  address: ""
  port: 0
  compress_responses: false
  downstream_url: ""
  tail_proxy_url: ""
  tail_tls_config:
    tls_cert_path: ""
    tls_key_path: ""
    tls_ca_path: ""
    tls_server_name: ""
    tls_min_version: ""
ruler:
  external_url: ""
  ruler_client:
    rate_limit: 0
    rate_limit_burst: 0
    backoff_config:
      min_period: 100ms
      max_period: 10s
      max_retries: 10
    tls_enabled: false
    tls_cert_path: ""
    tls_key_path: ""
    tls_ca_path: ""
    tls_server_name: ""
    tls_min_version: ""
  evaluation_interval: 1m0s
  poll_interval: 1m0s
  storage:
    type: local
    azure:
      account_name: ""
      account_key: ""
      endpoint_suffix: ""
      client_id: ""
      client_secret: ""
      tenant_id: ""
      max_retries: 5
    gcs:
      bucket_name: ""
      service_account: ""
      request_timeout: 0s
      enable_http2: true
    s3:
      s3: ""
      bucketnames: ""
      endpoint: ""
      region: ""
      access_key_id: ""
      insecure: false
      http_config:
        ca_file: ""
      sse:
        type: ""
        kms_key_id: ""
      backoff_config:
        min_period: 100ms
        max_period: 3s
        max_retries: 5
    bos:
      bucket_name: ""
      access_key_id: ""
    swift:
      auth_version: 0
      auth_url: ""
      username: ""
      user_domain_id: ""
      user_id: ""
      password: ""
      domain_id: ""
      domain_name: ""
      project_id: ""
      project_name: ""
      region_name: ""
      container_name: ""
      max_retries: 3
      request_timeout: 5s
    local:
      directory: /etc/loki/rules
  rule_path: /etc/loki/temp-rules-storage
  alertmanager_url: http://w.x.y.z:9093
  enable_alertmanager_discovery: false
  alertmanager_refresh_interval: 1m0s
  enable_alertmanager_v2: false
  notification_queue_capacity: 10000
  notification_timeout: 10s
  alertmanager_client:
    tls_cert_path: ""
    tls_key_path: ""
    tls_ca_path: ""
    tls_server_name: ""
    tls_min_version: ""
    basic_auth_username: ""
    basic_auth_password: ""
    type: Bearer
  for_outage_tolerance: 1h0m0s
  for_grace_period: 10m0s
  resend_delay: 1m0s
  enable_sharding: true
  sharding_strategy: default
  search_pending_for: 5m0s
  ring:
    kvstore:
      store: memberlist
      prefix: collectors/
      consul:
        acl_token: ""
        watch_rate_limit: 1
        watch_burst_size: 1
        cas_retry_delay: 1s
      etcd:
        endpoints: []
        dial_timeout: 10s
        max_retries: 10
        tls_enabled: false
        tls_cert_path: ""
        tls_key_path: ""
        tls_ca_path: ""
        tls_server_name: ""
        tls_min_version: ""
        username: ""
        password: ""
      multi:
        primary: ""
        secondary: ""
        mirror_timeout: 2s
    - ens5
    - eth0
    - en0
    - lo
    instance_port: 0
    instance_addr: ""
    num_tokens: 128
  flush_period: 1m0s
  enable_api: true
  enabled_tenants: ""
  disabled_tenants: ""
  disable_rule_group_label: false
  wal:
    tenant: ""
    remotewrite: []
    dir: ruler-wal
    truncate_frequency: 1h0m0s
    min_age: 5m0s
    max_age: 4h0m0s
  remote_write:
    enabled: false
    config_refresh_period: 10s
query_range:
  split_queries_by_interval: 0s
  align_queries_with_step: true
  results_cache:
    cache:
      background:
      memcached:
        expiration: 0s
        batch_size: 1024
        parallelism: 100
      memcached_client:
        host: ""
        service: memcached
        addresses: ""
        timeout: 100ms
        max_idle_conns: 16
        max_item_size: 0
      redis:
        endpoint: w.x.y.z:7001,w.x.y.z:7000
        master_name: ""
        timeout: 500ms
        expiration: 24h0m0s
        db: 0
        pool_size: 0
        username: ""
        password: ""
        tls_enabled: false
        idle_timeout: 0s
      embedded_cache:
        max_size_mb: 100
        ttl: 1h0m0s
      fifocache:
        max_size_bytes: 1GB
        max_size_items: 0
        ttl: 1h0m0s
        validity: 0s
        purgeinterval: 0s
      prefix: frontend.
    compression: ""
  cache_results: true
  max_retries: 5
  parallelise_shardable_queries: true
  forward_headers_list: []
runtime_config:
  period: 10s
  file: ""
memberlist:
  node_name: ""
  randomize_node_name: true
  stream_timeout: 10s
  retransmit_factor: 4
  pull_push_interval: 30s
  gossip_interval: 200ms
  gossip_nodes: 3
  gossip_to_dead_nodes_time: 30s
  dead_node_reclaim_time: 0s
  compression_enabled: true
  advertise_addr: ""
  advertise_port: 7946
  cluster_label: ""
  cluster_label_verification_disabled: false
  join_members:
  - memberlist.com
  min_join_backoff: 1s
  max_join_backoff: 1m0s
  max_join_retries: 10
  abort_if_cluster_join_fails: false
  rejoin_interval: 0s
  left_ingesters_timeout: 5m0s
  leave_timeout: 20s
  message_history_buffer_bytes: 0
  bind_addr: []
  bind_port: 7946
  packet_dial_timeout: 2s
  packet_write_timeout: 5s
  tls_enabled: false
  tls_cert_path: ""
  tls_key_path: ""
  tls_ca_path: ""
  tls_server_name: ""
  tls_min_version: ""
tracing:
  enabled: true
compactor:
  working_directory: ""
  shared_store: ""
  compaction_interval: 10m0s
  apply_retention_interval: 0s
  retention_enabled: false
  retention_delete_delay: 2h0m0s
  retention_delete_worker_count: 150
  retention_table_timeout: 0s
  delete_batch_size: 70
  delete_request_cancel_period: 24h0m0s
  delete_max_interval: 0s
  max_compaction_parallelism: 1
  upload_parallelism: 10
  compactor_ring:
    kvstore:
      store: consul
      prefix: collectors/
      consul:
        acl_token: ""
        watch_rate_limit: 1
        watch_burst_size: 1
        cas_retry_delay: 1s
      etcd:
        endpoints: []
        dial_timeout: 10s
        max_retries: 10
        tls_enabled: false
        tls_cert_path: ""
        tls_key_path: ""
        tls_ca_path: ""
        tls_server_name: ""
        tls_min_version: ""
        username: ""
        password: ""
      multi:
        primary: ""
        secondary: ""
        mirror_timeout: 2s
    - ens5
    - eth0
    - en0
    - lo
    instance_port: 0
    instance_addr: ""
  _: false
  tables_to_compact: 0
  skip_latest_n_tables: 0
  deletion_mode: ""
query_scheduler:
  max_outstanding_requests_per_tenant: 100
  grpc_client_config:
    rate_limit: 0
    rate_limit_burst: 0
    backoff_config:
      min_period: 100ms
      max_period: 10s
      max_retries: 10
    tls_enabled: false
    tls_cert_path: ""
    tls_key_path: ""
    tls_ca_path: ""
    tls_server_name: ""
    tls_min_version: ""
  use_scheduler_ring: false
  scheduler_ring:
    kvstore:
      store: consul
      prefix: collectors/
      consul:
        acl_token: ""
        watch_rate_limit: 1
        watch_burst_size: 1
        cas_retry_delay: 1s
      etcd:
        endpoints: []
        dial_timeout: 10s
        max_retries: 10
        tls_enabled: false
        tls_cert_path: ""
        tls_key_path: ""
        tls_ca_path: ""
        tls_server_name: ""
        tls_min_version: ""
        username: ""
        password: ""
      multi:
        primary: ""
        secondary: ""
        mirror_timeout: 2s
    - ens5
    - eth0
    - en0
    - lo
    instance_port: 0
    instance_addr: ""
analytics:
  reporting_enabled: false
verifyconfig: false
printconfig: true
listtargets: false
logconfig: false
configfile: /etc/loki/loki-conf.yaml
configexpandenv: false
````Preformatted text``Preformatted text`
Looks like timeout after 5 seconds. If you think the cluster is functioning, you can try increasing the client timeout to a bigger number and see if you can catch the potential problem behind the timeout.
Yes Tony, I got similar hint from older issues of missing logs and tried the same, log ingestion has increased and given warning logs disappeared.
msg="POST /loki/api/v1/push (500) 5.003777782s Response: "rpc error: code = DeadlineExceeded desc = context deadline exceeded\n" ws: false; Content-Length: 395858; Content-Type: application/x-protobuf; User-Agent: promtail/
the ““rpc error: code = DeadlineExceeded desc = context deadline exceeded”” has vanished but the given warning log still persists.
msg="POST /loki/api/v1/push (500) 10.00387309s Response: "context canceled\n" ws: false; Content-Length: 2263470; Content-Type: application/x-protobuf; User-Agent: promtail/2.8.4
Response: "context canceled\ is coming perhaps due to default timeout of 10s in promtail
clients:
  • url: http://loki.xyz.com/loki/api/v1/push
    batchwait: 1s
    batchsize: 1048576
    follow_redirects: false
    backoff_config:
    min_period: 500ms
    max_period: 5m0s
    max_retries: 10
    timeout: 10s
    tenant_id: xyz
    stream_lag_labels: “”
Seems this time its happening due to timeout at promtail agent’s end.
