Legend change issue with Grafana/Flux
This does work. I had to also add a column statement in the aggregate window to specify the new name and also did some regex transformations to remove the start and stop info in the legend.
Thanks
I reformatted the queries into 1 query in case it might help someone:
set energy = from(bucket: "xianenergyd")
    |> range(start: -30d)
    |> filter(fn: (r) => r._measurement == "xianenergy")
    |> filter(fn: (r) => r._field == "MAIN1_W" or r._field == "MAIN2_W" or r._field == "SOLAR1_W" or r._field == "SOLAR2_W" or r._field == "HOUSE1_W" or r._field == "HOUSE2_W" or r._field == "GARAGE1_W" or r._field == "GARAGE2_W" or r._field == "PI1_W" or r._field == "PI2_W" or r._field == "POOL1_W" or r._field == "POOL2_W" or r._field == "HVAC1_W" or r._field == "HVAC2_W" or r._field == "SHED1_W" or r._field == "SHED2_W" or r._field == "EV1_W" or r._field == "EV2_W" or r._field == "AC21_W" or r._field == "AC22_W" or r._field == "AC11_W" or r._field == "AC12_W")
    |> aggregateWindow(every: 1h, fn: mean, createEmpty: false)
    |> aggregateWindow(every: 1mo, offset: 7h, fn: sum, timeSrc:"_start")
    |> pivot(rowKey: ["_time"], columnKey: ["_field"], valueColumn: "_value")
    |> map(fn: (r) => ({ r with grid: r.MAIN1_W + r.MAIN2_W}))
    |> map(fn: (r) => ({ r with solar: r.SOLAR1_W + r.SOLAR2_W}))
    |> map(fn: (r) => ({ r with main:  r.HOUSE1_W + r.HOUSE2_W + r.GARAGE1_W + r.GARAGE2_W + r.PI1_W + r.PI2_W  + r.POOL1_W + r.POOL2_W + r.HVAC1_W + r.HVAC2_W + r.SHED1_W + r.SHED2_W + r.EV1_W + r.EV2_W}))
    |> map(fn: (r) => ({ r with battery: r.AC21_W + r.AC22_W - r.AC11_W - r.AC12_W}))
    |> drop(columns: ["MAIN1_W","MAIN2_W","SOLAR1_W","SOLAR2_W","HOUSE1_W","HOUSE2_W","GARAGE1_W","GARAGE2_W","PI1_W","PI2_W","POOL1_W","POOL2_W","HVAC1_W","HVAC2_W","SHED1_W","SHED2_W","EV1_W","EV2_W","AC22_W","AC21_W","AC11_W","AC12_W"])
energy
    |> yield(name: "energy")
