Ldap.toml configuration with windows active directory
Hello, We are using the lastest version of grafana under a Windows server 2016. Our AD is 2012. We are unable to set and connect to active directory or activate the verbose mode to help us finding the problem.
there is a part of our config files config files
[[servers]]
Ldap server host (specify multiple hosts space separated)
host = “ourDC.Ourdomain.local”
Default port is 389 or 636 if use_ssl = true
port = 389
Set to true if ldap server supports TLS
use_ssl = false
Set to true if connect ldap server with STARTTLS pattern (create connection in insecure, then upgrade to secure connection with TLS)
start_tls = false
set to true if you want to skip ssl cert validation
ssl_skip_verify = true
set to the path to your root CA certificate or leave unset to use system defaults
root_ca_cert = “/path/to/certificate.crt”
User search filter, for example “(cn=%s)” or “(sAMAccountName=%s)” or “(uid=%s)”
search_filter = “(sAMAccountName=%s)”
can you help us with this ?
bests regards,
Did you ever solve this? I have the same issue.
