Was able to set up Grafana with local user access but running into issues when trying to configure LDAP groups/users access. Tried bunch of things and none of that worked as expected. The Grafana pod was deployed as part of kube-prometheus operator install, so tried passing following configuration in custom values.yaml to the install set up but no luck. The container has admin.ldap flag set to true in grafana.ini but don’t see LDAP configuration either in the secret or in /etc/grafana/ldap.toml or in the secret.
The /etc/grafana/ldap.toml has default LDAP settings and don’t see any custom values specified in values.yaml.
grafana:
enabled: true
namespaceOverride: ""
rbac:
pspUseAppArmor: false
grafana.ini:
server:
domain: sandboxgrmysite.com
#root_url: "%(protocol)s://%(domain)s/"
root_url: https://sandboxgrmysite.com/grafana/
serve_from_sub_path: true
auth.ldap:
enabled: true
allow_sign_up: true
envFromSecret: "grafana-ldap-cred"
ldap:
enabled: true
existingSecret: ""
config: |-
verbose_logging = true
[[servers]]
host = "my.ldap.server.com"
port = 636
use_ssl = true
root_ca_cert = "/home/myid/CA_Cert.pem"
start_tls = false
ssl_skip_verify = false
bind_dn = "uid=ldapbind,ou=Users,dc=com"
bind_password = "${LDAP_BIND_PASSWORD}"
search_filter = "(uid=%s)"
search_base_dns = ["dc=com"]
[servers.attributes]
name = "givenName"
surname = "sn"
username = "cn"
email = "mail"
group_search_filter = "(&(objectClass=groupOfUniqueNames)
(uniquemember=%s))"
## An array of the base DNs to search through for groups. Typically uses ou=groups
group_search_base_dns = ["ou=groups,dc=Global,dc=com"]
## the %s in the search filter will be replaced with the attribute defined below
group_search_filter_user_attribute = "uid"
[[servers.group_mappings]]
group_dn = "cn=admin_ldap,ou=Users,dc=com"
org_role = "Admin"
grafana_admin = true
group_dn = "*"
org_role = "Viewer"
Spent some time looking at Helm templates and other configuration to understand what was missing and able to make it work with below configuration for Grafana in custom-values.yaml created from the operator.
Pay special attention to the indentation since that has caused some issues when I was trying to copy n paste from Grafana chart’s values.yaml. Only thing left is to read the bind password from an existing secret or environment variable, tried few approaches but those haven’t worked.
grafana:
enabled: true
rbac:
grafana.ini:
# To troubleshoot and get more log info enable ldap debug logging in grafana.ini
log:
mode: console
#level: debug
# to enable debug level for ldap calls only
#filters: ldap:debug
server:
domain: sbgrafana.mysite.com
root_url: https://sbgrafana.mysite.com/grafana/
auth.ldap:
enabled: true
allow_sign_up: true
config_file: /etc/grafana/ldap.toml
ldap:
enabled: true
# `existingSecret` is a reference to an existing secret containing the ldap configuration
# for Grafana in a key `ldap-toml`.
existingSecret: ""
# `config` is the content of `ldap.toml` that will be stored in the created secret
config: |-
[[servers]]
host = "my.ldap.com"
# Default port is 389 or 636 if use_ssl = true
# port = 389
# use_ssl = false
port = 636
use_ssl = true
# CA cert is mapped as certs-configmap in extraConfigmapMounts section below -- path in Grafana container
root_ca_cert = "/etc/grafana/ssl/CACert.pem"
start_tls = false
bind_dn = "uid=%s,ou=users,dc=myorg,dc=com"
bind_password = ""
name = "givenName"
surname = "sn"
username = "cn"
email = "mail"
## Group search filter, to retrieve the groups of which the user is a member (only set if memberOf attribute is not available)
group_search_filter = "(&(objectClass=groupOfUniqueNames)(uniquemember=%s))"
group_search_base_dns = ["uid=%s,ou=users,dc=myorg,dc=com"]
group_dn = "cn=admins,dc=grafana,dc=org"
org_role = "Admin"
group_dn = "cn=users,dc=grafana,dc=org"
org_role = "Editor"
group_dn = "*"
org_role = "Viewer"
extraConfigmapMounts:
- name: certs-configmap
mountPath: /etc/grafana/ssl/
configMap: certs-configmap
readOnly: true
Steps for creating configmap referenced above for LDAP SSL/HTTPS communication. At least I couldn’t find clear information, so adding here for others.
