Language support in timepicker
    10.0.1
    I want to achieve consistent German language support (Beta) in the Grafana GUI.
    I switched on German language support in General Settings as admin.
  • What happened?
    Dialogs displayed German names and descriptions very well. Problem: Timepicker time ranges are displayed in English still.
    I expected Timepicker texts to be in German too. Especialle time picker terms are not always ease to understand in English for a non-native user.
    n.a.
    No errors received.
    No.
Check out the following in your grafana config default.ini might help?
[date_formats]
# For information on what formatting patterns that are supported https://momentjs.com/docs/#/displaying/
# Default system date format used in time range picker and other places where full time is displayed
full_date = YYYY-MM-DD HH:mm:ss
# Used by graph and other places where we only show small intervals
interval_second = HH:mm:ss
interval_minute = HH:mm
interval_hour = MM/DD HH:mm
interval_day = MM/DD
interval_month = YYYY-MM
interval_year = YYYY
Thanks for the hint. I don’t think it will solve the problem.
Here is a screenshot how the time picker looks:
“Last 5 minutes” should be “Letzte 5 Minuten”
“This month so far” should be “Seit Monatsbeginn”
etc
It would be great if a translation of these terms could be part of the German language support in Grafana 10. If you need help I can make a proposal for the German translation of all the terms - am native German.
In that case clone grafana and change the code and build
I dont think grafana is an internationalized application… yet
Understand. Agree. Thx.
