Just latest image
- What are you trying to achieve?
I try install plugin for Grafana grafana-clickhouse-datasource
- How are you trying to achieve it?
I add plugins section to my helm values like this:
plugins:
- grafana-clickhouse-datasource
- What happened?
My k8s pod get down with this error in logs
Error: ✗ Get "https://grafana.com/api/plugins/grafana-clickhouse-datasource/versions": remote error: tls: handshake failure
I except what plugin will be successfuly installed and I can add clickhouse datasource.
- Can you copy/paste the configuration(s) that you are having problems with?
image:
# -- The Docker registry
registry: docker.io
# -- Docker image repository
repository: grafana/grafana
# Overrides the Grafana image tag whose default is the chart appVersion
tag: "latest"
sha: ""
pullPolicy: IfNotPresent
## Optionally specify an array of imagePullSecrets.
## Secrets must be manually created in the namespace.
## ref: https://kubernetes.io/docs/tasks/configure-pod-container/pull-image-private-registry/
## Can be templated.
pullSecrets: []
# - myRegistrKeySecretName
plugins:
persistence:
type: pvc
enabled: true
# storageClassName: default
accessModes:
- ReadWriteOnce
# annotations: {}
finalizers:
- kubernetes.io/pvc-protection
# selectorLabels: {}
## Sub-directory of the PV to mount. Can be templated.
# subPath: ""
## Name of an existing PVC. Can be templated.
# existingClaim:
## Extra labels to apply to a PVC.
extraPvcLabels: {}
## If persistence is not enabled, this allows to mount the
## local storage in-memory to improve performance
inMemory:
enabled: false
## The maximum usage on memory medium EmptyDir would be
## the minimum value between the SizeLimit specified
## here and the sum of memory limits of all containers in a pod
# sizeLimit: 300Mi
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No
- Did you follow any online instructions? If so, what is the URL?
How do we reproduce it?
- Create file with values for Helm Grafana values for Helm - Pastebin.com
- Install release with this command
helm install grafana grafana/grafana --values values.yaml -n test-grafana
- See what your pod is not running
k get pods -n test-grafana
did you solve this issue?
I’m getting the same: tls: handshake failure
