I am trying to output my k6 results to datadog locally.
I have tried the following:
Start datadog
DOCKER_CONTENT_TRUST=1 \
docker run --rm -d \
--name datadog \
-v /var/run/docker.sock:/var/run/docker.sock:ro \
-v /proc/:/host/proc/:ro \
-v /sys/fs/cgroup/:/host/sys/fs/cgroup:ro \
-e DD_SITE="datadoghq.com" \
-e DD_API_KEY=<YOUR_DATADOG_API_KEY> \
-e DD_DOGSTATSD_NON_LOCAL_TRAFFIC=1 \
-p 8125:8125/udp \
datadog/agent:latest
Run k6
K6_STATSD_ENABLE_TAGS=true k6 run --out statsd <my test>.js
I have also tried while supplying K6_STATSD_ADDR with
datadog:8125
the IP from my datadog docker process using
docker inspect -f '{{range .NetworkSettings.Networks}}{{.IPAddress}}{{end}}' datadog
With all these, I get a similar error from k6 that the metrics are not going though.
ERRO[0005] Couldn't flush a batch error="write udp 192.168.1.246:49185->172.17.0.2:8125: write: connection refused" output=statsd
Any ideas would be appreciated, thanks!
Hi @kghelani
The issue seems not really related to the k6. It just tells you that couldn’t reach the address.
What I see is that you exposing the port to the host:
kghelani:
-p 8125:8125/udp
So in theory it should work with the standard k6’s K6_STATSD_ADDR which is localhost:8125. For sure if k6 is running on the same host machine.
If it doesn’t work with this address I’d recommend checking the documentation of the datadog/agent to see why it could refuse the connection.
Hope that helps,
Cheers!
I encountered the same issue as @kghelani (write: connection refused" output=statsd), and seemed to overcome it by using the container IP directly, as such:
$ docker inspect -f ‘{{range .NetworkSettings.Networks}}{{.IPAddress}}{{end}}’ dd-agent
172.17.0.2
Then:
K6_STATSD_ADDR=172.17.0.2:8125 K6_STATSD_ENABLE_TAGS=true k6 run --out statsd ./load/sample.test.js
No metrics seem to have been received by the agent, although the test seems to run successfully:
Here’s how I initialized my local DD Agent FYI:
docker run --rm -d
–name dd-agent
-e DD_SITE=“datadoghq.com ”
-e DD_API_KEY=“”
-e DD_DOGSTATSD_NON_LOCAL_TRAFFIC=true
-e NON_LOCAL_TRAFFIC=true
-p 8125:8125/udp
Any help appreciated!
rodyb
April 18, 2023, 2:52am
4
Hi @kghelani @gurgelv
Let me know if this works for you.
Hi @rodyb ,
I’ve done almost the same, Still no metrics forwarded to Datadog, without errors,
I don’t see what the problem can be,
below the nc command return to be sure that the connection is well established with to agent through this IP address,
nc -vz -u 172.17.0.2 8125
Connection to 172.17.0.2 port 8125 [udp/*] succeeded!
Any other suggestions ?
Thank you,
Ghassen.
rodyb
September 5, 2023, 9:44am
8
hi @ghassenjn ,
Can you try this and let me know what the error shows?
version: '3.7'
volumes:
datadog:
services:
datadog:
image: gcr.io/datadoghq/agent:7
networks:
- k6
container_name: dd-agent
restart: always
ports:
- 8125:8125
environment:
- DD_API_KEY=<KEY>
- DD_SITE=datadoghq.com
- DD_DOGSTATSD_NON_LOCAL_TRAFFIC=1
- DD_APM_ENABLED=true
- DD_LOGS_ENABLED=true
- DD_LOGS_CONFIG_CONTAINER_COLLECT_ALL=true
- DD_DOGSTATSD_NON_LOCAL_TRAFFIC=true
volumes:
- /var/run/docker.sock:/var/run/docker.sock:ro
- /proc/:/host/proc/:ro
- /sys/fs/cgroup/:/host/sys/fs/cgroup:ro
k6:
image: loadimpact/k6
networks:
- k6
container_name: k6
depends_on:
datadog:
condition: service_healthy
command: run -e K6_STATSD_ADDR=datadog:8125 -e K6_STATSD_ENABLE_TAGS=true --out statsd tests/<Sometest.js>
volumes:
- .:/app:delegated
networks:
k6:
I am not sure what problem you exactly have, however I also ran into an issue with this
Make sure this is either europe or US, depending on where Datadog is hosted for you.
Can you show me the errors that you see?
Hi @rodyb ,
Thank you for your response,
I got those errors =>
dd-agent | 2023-09-05 11:48:27 UTC | CORE | ERROR | (comp/forwarder/defaultforwarder/worker.go:198 in process) | Error while processing transaction: error while sending transaction, rescheduling it: Post "https://7-47-0-app.agent.datadoghq.eu/api/v1/check_run": tls: failed to verify certificate: x509: certificate signed by unknown authority
2023-09-05 11:48:38 UTC | PROCESS | ERROR | (comp/forwarder/defaultforwarder/worker.go:194 in process) | Too many errors for endpoint 'https://process.datadoghq.eu/api/v1/container': retrying later```
rodyb
September 5, 2023, 12:06pm
10
Hi @ghassenjn ,
I don’t know what site you are testing but can you try to run it with this flag?
k6 run tests/script.js --insecure-skip-tls-verify
This should disable the certificate.
I have started trying out k6 today and I am impressed.
I see a problem with https requests made to a test server.
WARN[0003] Request Failed error=“Get "https://127.0.0.1:4433 ": x509: certificate signed by unknown authority”
it is self signed certificate. I don’t want disable the tls verify. Because we are testing tls 1.3 testing
please help me with this guys
Thanks in advance
Sorry, I update my post, I got the same problem which is related to the tls certificate,
dd-agent | 2023-09-05 14:40:53 UTC | CORE | ERROR | (comp/forwarder/defaultforwarder/transaction/transaction.go:115 in 4) | TLS Handshake failure: tls: failed to verify certificate: x509: certificate signed by unknown authority
rodyb
September 6, 2023, 6:28am
12
Hi @ghassenjn ,
I need a bit more information to understand the issue better.
A couple of things I need.
How does your test look like ? Can you share that here ?
Can you share here, how you run the test? (what command exactly?)
Have you tried to use a different URL, then you use now and see if the problem persists?
Thanks.
