X509: certificate signed by unknown authority
I have started trying out k6 today and I am impressed.
I see a problem with https requests made to a test server.
WARN[0003] Request Failed error=“Get "https://127.0.0.1:4433": x509: certificate signed by unknown authority”
it is self signed certificate. I don’t want disable the tls verify. Because we are testing tls 1.3 testing
please help me with this guys
Thanks in advance
Hi there, welcome to the forum :slight_smile:
If you don’t want to run with --insecure-skip-tls-verify, I think your only option is to add the root CA certificate to your local store.
On Linux this would involve the ca-certificates package and copying your cert to the correct location. This will be system dependent, but see the instructions for Ubuntu, otherwise consult your OS documentation.
Hope this helps,
Ivan
Have added all the required certificates on windows, still getting same error.
Please help me in fixing this @satyakommula
