I am trying to use Server gRPC streamin. How can i pass accesstoken in stream method ??
Hi @irfanspursll !
Welcome to the community forums!
If your access token is stored in metadata, you could use the params
argument of the Stream
class.
Stream(client, url, [,params])
The params object documentation is there Params | Grafana k6 documentation.
P.S. While checking your case, I found that our documentation lacks these details. So I’ve also opened the PR gRPC Stream class docs by olegbespalov · Pull Request #1535 · grafana/k6-docs · GitHub to fix it.
Let me know if that helps
Cheers!
Thankyou so much @olegbespalov . I was able to pass it using params thanx for the tip.
const params = {
metadata: {
'accesstoken': accessToken,
const stream = new Stream(client, serviceName,params);
Yes, You are correct the documentation lacks the details about the params for stream call.
