Hello. I’ve just setup the k6-operator and I just noticed that there is a parameter to send metrics to prometheus. Here are the docs and the corresponding value parameter here.
So far I was using the prometheus remote write to send testss results but what is this about? I couldn’t find any other mention to this and on what metrics does it send. Also, I enabled it and I didn’t receive any k6_* metrics to the Prometheus through its ServiceMonitor.
Any ideas on what metrics does this provide?
The prometheus.enabled parameter in k6-operator doesn’t push metrics to Prometheus. Instead, it creates a metrics endpoint that Prometheus can scrape.
When you enable this parameter, the k6-operator sets up:
- A metrics service exposing k6 performance data
- A ServiceMonitor custom resource (if you have Prometheus Operator installed)
For this to work properly:
- Make sure your Prometheus instance is configured to discover ServiceMonitors
- Check that the ServiceMonitor labels match your Prometheus instance’s serviceMonitorSelector
- Verify the metrics endpoint is actually receiving data (you can port-forward to the service and curl the
/metrics endpoint)
The metrics should include standard k6 performance data (request rates, response times, errors) with the k6_ prefix.
