Here is my flow:
K6 run -o cloud xx.js (K6 cloud results are good) ===> Prometheus ===> Grafana cloud
Below steps worked on to make my load test results visible on grafana cloud:
I have javascript that works fine for k6 local and cloud to publish results. for prometheus i have added below sample code.
I have updated K6 → Cloud APM configuration for prometheus
also, added grafana cloud with “prometheus details”
Added new data source to grafana and made sure data source is working with basic authentication.
export const options = {
ext: {
loadimpact: {
apm: [
provider: 'prometheus',
remoteWriteURL: '<Remote Write URL>',
// optional parameters
credentials: {
username: '<user>',
password: '<token>'
includeDefaultMetrics: true,
metrics: ['http_req_sending', 'my_rate', 'my_gauge'], //...other options,
includeTestRunId: false,
resampleRate: 3,
Result: I am not seeing prometheus as per below screen shot from my k6 cloud account… also, grafana with prometheus dashboard don’t saw anything.
