I am trying to use free cloud executions for 50 tests at least.
But every-time i get some subscription issues.
If i try from my MAC machine to run through still i get some error or even i try using Azure pipeline running in the cloud, still i face same error.
Running in cloud is not free??
Error from local
Aborted by limitArchive validation failed for test_run_id=746167: The subscription of organization 'pawan's default organization (1131569)' doesn't allow for starting k6 cloud test-runs. (3114)
Error using Azure
RRun k6 cloud load test within Azure Pipelines
1. Starting: RRun k6 cloud load test within Azure Pipelines
Task : Command line
Description : Run a command line script using Bash on Linux and macOS and cmd.exe on Windows
Version : 2.164.2
Author : Microsoft Corporation
Help : https://docs.microsoft.com/azure/devops/pipelines/tasks/utility/command-line
Generating script.
Script contents:
k6 cloud --quiet cloud.js
========================== Starting Command Output ===========================
/bin/bash --noprofile --norc /home/vsts/work/_temp/41fcee62-ae11-43aa-973f-bf2a7c081e6d.sh
/\ / \ | |_/ / / /
/ \ | |‾\ \ | (_) |
/ __________ \ |__| \__\ \___/ .io
uploading script [----------------------------------------------------------]
time="2020-06-13T07:17:05Z" level=error msg="(400/E3114) Too many load zones for subscription: 2 > 1."
##[error]Bash exited with code '255'.
Finishing: RRun k6 cloud load test within Azure Pipelines
