Hi K6 newbie here…
With K6 Browser, I’m trying to select an item from a menu list
//*[@id=“menu-state”]/div[3]/ul
The list contains whole bunch of items:
//[@id=“menu-state”]/div[3]/ul/li[1]
//[@id=“menu-state”]/div[3]/ul/li[2]
//[@id=“menu-state”]/div[3]/ul/li[3]
My code is like this:
const w = page.locator('//[@id=“menu-state”]/div[3]/ul’);
w.selectOption(‘Iowa’);
Got error:
Uncaught (in promise) GoError: selecting option on “//*[@id="menu-state"]/div[3]/ul”: read tcp 127.0.0.1:31281->127.0.0.1:31280: wsarecv: An existing connection was forcibly closed by the remote host.
default at github.com/grafana/xk6-browser/api.Locator.SelectOption-fm (native)
Meanwhile, if I click on the list to expand it, the locator becomes "//[@id="selectLabelId"]".
If I call page.locator(//[@id="selectLabelId"]).selectOption(‘Iows’), there is error:
Uncaught (in promise) GoError: selecting option on “//*[@id="selectLabelId"]”: strict mode violation, multiple elements returned for selector query
Any suggestions?
Thanks a lot,
-Madison
Ok. I made some progress. First, expand the menu list; Second, select a menu item.
//This solved “multiple elements return” issue:
page.locator(‘(//*[@id=“selectLabelId”])[2]’).click();
//This bypasses selectOption():
page.locator(‘//*[@id=“menu-state”]/div[3]/ul/li[1]’).click();
Hi @madisonli, welcome to the forum! ![:wave: :wave:](https://emoji.discourse-cdn.com/twitter/wave.png?v=12)
Could you please post the full test script? Which version of k6 are you using?
Hi Daniel,
My k6 version:
k6 v0.45.0 (2023-06-19T08:41:01+0000/v0.45.0-0-gc3b4587b, go1.20.5, windows/amd64)
My original script was:
const w = page.locator(‘//*[@id=menu-state]/div[3]’);
w.selectOption(‘AK’);
It didn’t work.
Thanks,
-Madison
Could you post the full script @madisonli ? Does it reference a public site that we could also test?
In regards of the issue:
As the error message says, Locator
uses “strict mode”, which means that it only allows selectors that specify a single element. If you can not refine the selector to reference a single element, or if you want to select more than one element and then iterate through them, you can use the $$
query selector.
